Badger5JMB Retrofits
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Oil filter housing breather hose question-BOOST LEAK?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Post Oil filter housing breather hose question-BOOST LEAK?
    I have found that the crankcase breather hose on the oil filter is bust. I had a look on vagcat.com for the part number and on the diagram it shows this pipe is blanked off on the oil filter housing.
    Car : 2001 S3 AMK
    Part number : 06A115418
    My question is, will there be a problem with blanking the oil filter housing? Will this cause extra pressure in the engine or will the pressure be released into the rocker cover and out through that breaker hose.
    What I would like to do is blank off the oil filter breather with $3 part and fit a oil catch can. Will be one less hose it the bay to plumb.
    New genuine replacement breather hose is around $50.
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Are you talking about the 90 degree solid pipe, its probably best to have it as a breather, as it will stop the pressure building up in the lower part of the engine, additional pressure might find it's way out somewhere else and cause leaks,
    There's a very good guide in the stickys for how to install a catch tank and simplify the breather system
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Yip, thats the pipe. I find it strange that there is a part number for the piece to blank this breather off.
    I had a look at the sticky, going to do this but was wondering if blanking of the breather does cause issues.
    Common sense is telling me I need the breather pipe
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    fitzdog88 likes this.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Same one, thanks Tuffy, you a legend.
    Funny how I cant search for that part on Ebay from here in Dubai.
    Another question about all those pipes.
    The part # 06A-133-783-AS that comes off under the mani, divides into 2, 06A-133-783-BA and 06A-133-783-AT
    06A-133-783-BA then divides again, one goes to 06A-133-789 and the other goes back to the mani.
    When I fit a catch can, must I block off the fitting under the mani and use the fitting on the left side of the mani to feed 06A-133-789 and keep the check valve in the system?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Sorry, my bad.
    Its not ebay, its amazon!!!!
    And I had a look at the sticky again, shows the plumbing.
    Note to self, never go full retard!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    You essentially bin most of the stuff in the pic above... I have posted about this a few times tbh but for the PCV/catch tank solution you replace the rubber 'T' (06A 103 247) with a stright piece of rubber or silicon hose to the plastic pipe going to the top breather...
    Under the inlet mani you keep the small vac feeds to the FPR and DV/N249, block off the PCV one in the middle and disassemble the servo hose from the 'V' hose setup on the end of the manifold just fixing this the outlet coming out the mani on the end (cyl 1)
    There is a check valve by the servo on the S3 so no need to fit anything else...
    <tuffty/>
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    never hold back the inner retard, i set mine free very often!
    on my a3 i blocked the nipple from the underside of the mani, and plugged one of the splits on the hose that goes to the brake servo, looks like its different on the s3 tho,
    1.8T SPORT AUM
    Progression Thread
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Why do I get air blowing out the dipstick pipe and this broken crankcase breather pipe when I do a boost leak test?
    I can't wrap my head around this. Is the air pushing past the piston rings and into the crankcase? I have put 2bar into the TIP and the system won't stay pressurised, air is flowing out the breather pipe and dipstick as quickly as its flowing into the system. Can that much air pass by the rings or is there a major problem?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Quote Originally Posted by Scullies View Post
    Valves will be open allowing pressure to enter the cylinders and subsequently the block... finds it way back out the dipstick etc... hence the reason you can't block the PCV in the block else it will blow out the filler cap along with your engine oil
    Not enough pressure to seal the rings in the cyl on a boost leak test... so will easily blow past...
    <tuffty/>
  1. Leaking coolant Hose From Oil Filter on S4....
    By s4best4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2011, 22:24
  2. 1.8T Part needed, Oil filter housing
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2010, 13:40
  3. Breather Hose
    By Scouse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2009, 19:15
  4. oil filter housing valve
    By treblesykes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2007, 21:39
  5. Breather hose?? 2.8 V6
    By Chilli in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th August 2006, 06:47
