JMB RetrofitsChris Nott
Results 1 to 7 of 7
    Mar 2011
    Milton keynes
    150
    Strange noise ?.. :/
    Hi all,
    Ive noticed a strange noise whilst driving and cant put my finger on what it is. It sounds like a wheel bearing sort of drone but it isnt influenced by turning or sudden changes with the steering. Its intermittent and seems to only be at around 55mph whilst just entering boost on my turbo boost guage :/ its an odd one and something im confused over.
    if i ease off the speed and pedal it quietens the noise till it dissappears.
    So basically its heard when doing a steady speed usually 55ish sometimes 30ish and appears to be related to pedal position too.
    Any ideas will be appreciated , cheers
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    How worn are your tyres? I had this a year ago and it drove me nuts, new tyres solved it, the old ones were well worn and making the noise.
    Hope this helps, noises are a swine to track down
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Coming from the front or rear?
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Mar 2011
    Milton keynes
    150
    Thanks for your posts guys,
    Just put four new tyres on it and the noise seems to be from the front.
    Jon
    Mar 2011
    Milton keynes
    150
    Bump.. Could the noise be anything to do with the recirc valve ? i had a fault code a while back hinting it was playing up, could this failing make an intermittent noise ? ,
    Cheers, Jon
    Mar 2011
    Milton keynes
    150
    For those of you that responded to this originally I found a small split in my intake pipe which when I replaced the item for a nice new silicone one it stopped this noise yay! My car runs like new again :-)
    Nov 2012
    44
    JonBoi Im also having this problem and posted but couldn't get any definitive advise, your find sounds like its right on the money, and come to think of it the sound seems to come from behind passenger side of dash which is where this b****rd TIP lies. Will be giving this a look see when I get the car back from body shop next week thanks for this.
  1. Audi A3 1.8T (8l AUM Engine): Strange noise - grinding/rubbing noise..
    By pangsterA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 21:01
  2. strange noise
    By simon1303 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2007, 10:08
  3. Strange noise
    By hamski in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2006, 22:06
  4. Strange noise..
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 00:44
