EM TuningVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 78
Thread: Piston Rings
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Piston Rings
    I've recently bought some forged rods so I've got the rods n pistons out, I've got some new big end bearings and was wondering if it would be sensible to change the rings as well? If so, where do I get them from as having trouble finding any a part from ones on ebay from lithuania.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    TPS around £120 + vat ive just bought some.... mine needed doing, all 4 was letting oil through
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,099
    Iirc I got mine from audi for just over £120 Inc vat but that was with discount
    So are you finally rebuilding yours with a possible hybrid?
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    If you're thinking of changing the rings you will need to hone each bore and make sure the rings are gapped correctly. I'm goin to leave my piston rings alone unless they are in serious need of changing.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Quote Originally Posted by Westy View Post
    Hmmm, Is that a must? Just because I'm not really too sure if my bores were honed when my rings where done? They wernt faulty, just had them replaced?
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by S3featesV9 View Post
    I'm no engine expert but I was under the impression that the bores needed to be honed to ensure a good clean surface for the new rings.
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    You will need to hone the bores if fitting new rings else they won't be able to bed in properly and not seal... you would end up causing more issues than you started with... honing can be done with the engine in situe using a honing tool on a drill...
    Caution should be taken for obvious reasons and make sure you cover the crank journals while you do it and make sure everything is cleaned after with brake cleaner or similar..
    Laser Tools 2070 Engine Cylinder Hone
    Pay especially careful attention to the oil squirters...
    <tuffty/>
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    The rings are about 15-20quid per cylinder from Jason at All German Parts.
    As above you will need to hone the bores, but it can be done without removing the engine/crank.
    Personally i think its crazy to remove the pistons from an engine and NOT fit new rings. Sure they may well be fine, but so were the bearings, and you replaced those... Especially when the plan is to tune the engine, having as much of the motor fresh as possible will ensure a better end result.
    TD5 Land Rover Defender build
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Westy, defo do the rings if the rods/pistons are out. Mine wasn't letting any oil through then this happened
    Westy's Avatar
    Dec 2008
    17,283
    Sandip, I still don't know what happened to your old 1.8T lump?!
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Piston ring shattered and took a chunk of the piston with it. I had major detonation, possibly dodgy fuel what was the cause. The head looked like someone had been at it with a chisel....really bad!
    I'm surprised i didn't bend a rod to be honest
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by sandip View Post
    Blimey. I'll be checking the rings on mine but I don't want to attempt the honing myself as I can do more harm then anything.
    S3 Build Thread
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Honing the bores and doing the rings would give you the peace of mind and take away any doubts in the future......
    Westy's Avatar
    Dec 2008
    17,283
    Unfortunately I don't have the time to get the block out to take to an engine specialist to get honed. Welly used his old rings and his car is going strong. I'll check them over when the pistons are out and I'll change them if they definitely need doing but it will probably end up delaying the build a bit.
    S3 Build Thread
    beachbuggy's Avatar
    Surrey
    1,746
    Rings per set from GSF are £11 so £44 in total. Definately hone bores.
    "Stick a V8 in it!"
    15,388
    how are you going to know if they "definitely need doing"?
    Didnt Tufftys break a ring after reusing them...
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Fair enough bud, you've got better luck than me so the chances of a major disaster like mine are slim! lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    You can hone with the block in place bud... if I were closer I'd do it for you
    <tuffty/>
    Westy's Avatar
    Dec 2008
    17,283
    <tuffty/>
    So do I mate.
    I have a couple of big worries like honing too much or at an angle where the block is in situ, or wrecking an oil squirter and needing to fix that!
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Went to see my car today at RStuning, and i saw a broken ring by the tool tray, and asked was that mine,? and he said yes, it snapped clean in half when the piston ring compressor released it... proberbly thousands of heat cycles then a sudden pressure release..150k milage though...
    Westy's Avatar
    Dec 2008
    17,283
    Ideally I could do with an ASN member who has done honing before and has all the kit to pop round mine Easter Weekend and lend a hand
    S3 Build Thread
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I think I do too. Garage said they didn't get it honed!! Wtf?
    I've done about 1100 miles since then and no issues yet?
    Westy's Avatar
    Dec 2008
    17,283
    If honing didn't need to be done and I could just slap new piston rings in I'd do that!
    S3 Build Thread
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    garage said they didnt see any reason too as the bores were fine, and could still see the cross hatch on bores. so just did a quick deglaze with hot water and sos pad. apparently only need honing if you cant see the cross hatch?. if it needed it then it would of been sent away with the crank.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Depends on the definition of 'honing' I guess... I use the hone tool I linked to above and deglaze/add cross hatch to the bores... while this isn't honing in teh traditional sense it will serve to do the same thing at the end of the day... just because you can see the cross hatch doesn't mean it will be much use in bedding in new rings tbh... a quick run up and down the bore with a honing tool such as the Laser one is usually more than enough...
    <tuffty/>
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    your right in saying that, if your going to do a job...then use the right tools. just thinking that maybe westy could use same method as the garage i used if he doesnt have access or feel comfortable using the drill bit. although theres only one way to learn, its not too expensive either.
    take twice as long though and more elbow grease using a steel wool pad too.
    garage have told me not to worry, so thats some weight off the shoulders.
  28. #27
    "Stick a V8 in it!"
    15,388
    the yanks seem to like the flexhone tools, i've got a 1.8T sized one you can borrow if you want.
  29. #28
    Westy's Avatar
    Dec 2008
    17,283
    <tuffty/>
    Ok guys, you've finally done it! You've persuaded me to do the sodding rings
    Aragorn if you dont mind me borrowing your honing brush I'll pay the postage and hook you up for a few beers too.
    Can anyone confirm what rpm drill I will need to use this tool?
    S3 Build Thread
  30. #29
    Westy's Avatar
    Dec 2008
    17,283
    Also is the bore 81mm when buying rings?
    S3 Build Thread
  31. #30
    "Stick a V8 in it!"
    15,388
    I just used my variable speed mains drill and just sort of guessed the speed after watching a few youtube videos :P
    Standard bore is 81mm yes.
  32. #31
    Westy's Avatar
    Dec 2008
    17,283
    Cheers. Just ordered the rings.
    If I PM you my address are you ok to post me the brush and invoice me for postage?
    S3 Build Thread
  33. #32
    monkey_lewis's Avatar
    Jan 2011
    CANVEY ISLAND
    202
    Dont want it high tho
    Mirror, Signal........ wave bye bye!!
    Audi A3 1.8Ti
    a.k.a. binky the panda
  34. #33
    "Stick a V8 in it!"
    15,388
    yeh, iirc the video did two speeds, so many strokes slowly and so many strokes at a higher speed.
    Westy: yeh i can send you the tool
  35. #34
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    I used the 1st speed on a battery drill for mine... just felt more in control if I did manage to catch the squirter...
    <tuffty/>
  36. #35
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Where from bud? Care to share cost too
  37. #36
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by Byzan Photography View Post
    Audi VW 1.8 20v 1.8T TT Passat turbo Engine Piston Rings set STD | eBay
    £78 only 1 set left, be quick
    S3 Build Thread
  38. #37
    beachbuggy's Avatar
    Surrey
    1,746
    Sorry for asking but why are you buying rings from Latvia for £78 when you can pick up perfectly good ones from a named brand from GSF for 1/2 the price?
  39. #38
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,377
    Westy, are they genuine in any way? Would you perhaps not be best off going for some direct from TPS? or through jason? or am I missing something on the ad?
  40. #39
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by beachbuggy View Post
    Nobody said they were half that price, they said £15-£20 per bore which is still £60-£80. Plus it's easier for me to click a few buttons then to phone GSF and ask for "Jason" and ask for a discount etc.
    S3 Build Thread
  41. #40
    beachbuggy's Avatar
    Surrey
    1,746
    I said here! I'd even have given you the part number.
  1. 8P3 A3 Chrome Fog Rings - Will swap my Black Optics Rings
    By Chappy in forum For Sale/Wanted - Audi Parts
    Last Post: 1st September 2011, 23:43
  2. help please...turbo or piston rings
    By kooch_481 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd August 2010, 20:10
  3. piston rings
    By lugz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2010, 10:21
  4. ... Piston rings?..
    By mk1rolf in forum S2/RS2 Forum
    Last Post: 14th July 2007, 08:09
  5. Help! Piston Rings?
    By NPFX in forum TT/TT-S/TT-RS Forum
    Last Post: 17th November 2006, 11:25
