Results 1 to 7 of 7
Thread: Injectors
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Injectors
    Finally got a final figure for "stage 2" cost wise, but not sure about injectors......
    I'm pretty sure its the 380cc one's im gonna need - but surely they are not £125 EACH!
    Any other alternatives / substitutes?
    Also - whats the repercussions on using my standard jets>?
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Assuming you are still going for a K03 hybrid then S3, TT (225) or LCR injectors are the ones you want... can be bought from ebay or other places...
    If going for a K04 hybrid then you will be looking for 440cc or 550cc injectors...
    You will also need the MAF tube from a VR6 or S3, TT (225) or LCR depending on the ECU you have (can't remember if its ME7.x or ME3.8 on yours)
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    ...and there isn't enough flow on the std injectors for what you need...
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    Are you cable throttle or DBW marcus? This hugely effects all further comments as Tufty says.
    Being that you've upgraded to a ko3S, i'm guessing it's closer to AGU than AUQ, but i don't take enough interest in TQS matters to be sure
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    DBW mate.
    I only know because it dosnt have a cable by the inlet manifold like i have seen on others
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    In that case its a nice set of 550cc Bosch then... I think Bill normally keeps a set on the shelf... drop him an email
    <tuffty/>
    Sep 2011
    Isle of Man
    175
    If Bill hasn't got any just got mine from IE in the States took 6 days to arrive only $49 each so with the exchange rate good value.
    Bosch 52LB / 550cc Hi Impedance Injector
    Martin
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
  1. Replies: 11
    Last Post: 11th February 2012, 15:46
  2. 1.8t sport a4 injectors,audi tt injectors,aeb inlet, and other bits
    By tsporta4 in forum For Sale/Wanted - Miscellaneous
    Last Post: 10th July 2011, 19:08
  3. Injectors
    By noddys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 17:13
  4. which injectors?
    By mike1234 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2008, 11:00
  5. Changing S3 210 injectors to 225 injectors
    By brucelee1973 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2007, 17:46
