Volks AutosAH Fabrications
    Jan 2012
    9
    front suspension really pi@@g me off
    hi i keep getting a knock noise when i pull away at lights, from off side front, i have change both wish bones, front wheel bearings, both stabliser links, both anti rollbar rubbers, lower ball joint, top mount rubbers.????
    any ideas, i guess it leaves top mount bearings and shocks.
    all bolts etc checked to make sure there tight.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,503
    Should have change the top mount bearing whilst doing the rubbers! I'm guessing it's this.
    beachbuggy's Avatar
    Surrey
    1,744
    Loose brake pad? Had the same trouble before after changing everything turned out to be one of the pads was loose in the carrier and clinked on pulling away and bumps. Worth a look. Either that or possibly drive shaft knocking on arb.
  1. Front suspension bushes
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2010, 22:35
  2. Front suspension all the same?
    By ian52 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2009, 18:44
  3. squeky front suspension
    By misledyouth in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2008, 12:26
  4. Clunk from front suspension, not suspension arms though?........
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2008, 21:37
  5. Front Suspension
    By DAMO1.9TDI in forum Handling
    Last Post: 28th October 2006, 23:31
