Badger5JMB Retrofits
Thread: heat wrap
    coatesy's Avatar
    poking badgers with spoons
    Mouse Race Champion, Fishing the Sea Champion
    Oct 2010
    Middlesbrough, United Kingdom
    1,901
    heat wrap
    i was thinking of getting some heat wrap to put around my hot side intercooler pipe work, im pretty sure it looked like 16Klappe had some on his a3 pipe work.
    i just wanted to get people opinions, i think of it this way wrap the pipes and less heat will be dispersed in to the engine bay therefore making the engine bay hotter. the other thing i thought of would be heat soaking the pipes because its got the wrap on but the hot air will be going through the front mount to be cooled down.
    i have done some research and some people say its good some say its bad what are your thoughts.
    no need to rage post because that just makes you gay
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    I wouldnt bother to be honest. I took mine for a very spirited drive on the weekend. Pulled over to check under the bonet.the ic pipe off the turbo was warm enough to touch but the throttle body side was ice cold. Don't think there is any need really. If anything, put the heat wrap on the turbo
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Heat wrap your manifold and exhaust.
    +1 on paradox1 aswel
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    coatesy's Avatar
    Oct 2010
    1,901
    safe im going to do abit of testing with this to see what happens
  1. Heating stops giving out heat .. after 10 seconds or so it will give out heat ???
    By jay786 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th February 2012, 18:30
  2. Heat wrap.....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2011, 22:40
  3. Red hose from turbo to inlet pipe.... should it have heat wrap???!!!
    By AWDMk1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2010, 06:25
  4. Intake Heat Wrap- About to commence..is it worth covering the fuel lines?
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 23:21
  5. Heat wrap on down pipe?
    By BOSSS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 10:02
