Volks AutosJMB Retrofits
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Fitting new ds2 bulbs.....
    How the hell do those ds2 bulbs come out of the lense? I have twisted off the ballast connection from rear of bulb. But I can't figure out how the bulb comes out. Is it pull? Twist? Or is there a locking spring?
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    On mine (A4) theres a circular locking ring on the outside of the bulbholder that you twist off, then the lamp itself just lifts out.
    TD5 Land Rover Defender build
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Cheers mate, shall check it out. Trying to be carefull aswell due to my lights currently falling apart inside!
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Well that was more hassle than it was worth. Ended up completely breaking the inside of the offside headlamp. The internal part moves forwards and backwards
    Any advise to weather what is actually broken? Small white part is in the lense too, but that's always been there???
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    Have you got any pictures?
    The part the bulbs are mounted in - is this the bit that's wobbly? Hopefully you just pushed the rubber mountings of the adjusters.
    If you broke something you may need to epoxy it back together.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Can DS2 Bulbs be fitted to my car with DS3 Bulbs fitted standard?
    By SimplyTheBest1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2011, 15:39
  2. Fitting new bulbs, do i need to remove the headlight?
    By medicpaul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2011, 07:29
  3. Tutorial - Fitting new bulbs in Bi-Xenon headlights
    By smudge_don in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th May 2010, 18:12
  4. Fitting LED sidelights bulbs leads to failure
    By heeman10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2009, 18:20
  5. Fitting Silverfusion bulbs
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 13:40
