Results 1 to 12 of 12
    got an S3 8L: living the dream
    Mar 2010
    Kent
    173
    Question first warm day.....no cold air from vents :( .....where do i start?
    so yesterday was the 1st time the car really got warm in the sun..........noticed the coolest i could get from the vents was ambient temp.
    last service (oct 2011) audi confirmed something like -5degC from the vents, so was ok then.
    So my question is: Where do i start looking for the problem?
    Is there somewhere in vcds i can look for an HVAC temp diagnostic?.......what are the other likely options i have? (other than paying someone to look at it....which i would prefer not to!)
    Any advice is much appreciated......would like to get it sorted before a possible hot summer!
    2002 S3 8L AMK
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    can you turn the econ off on the cc unit ?
    Mar 2010
    Kent
    173
    i have the unit on "auto" all the time other than when i am using the front screen demist........ dont think auto uses the econ setting.
    even when set to "LO" the air is ambient temp.
    2002 S3 8L AMK
    bez101's Avatar
    Jul 2008
    8,534
    you need econ off auto off and set to low for cold air
    go do that you should have cold air
    Mar 2010
    Kent
    173
    checked that out today......have to say that i still think only ambient air is coming out.
    does anyone know if there is a less subjective test i could do?
    2002 S3 8L AMK
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Probably needs refilling tbh..... if you do a scan in VCDS I think it should throw a fault code if the pressure is too low....
    <tuffty/>
    Mar 2010
    Kent
    173
    <tuffty/>
    Cheers tuffty - will try to check for codes tomorrow.
    I am expecting to potentially be shot down in flames and told to wash my mouth out......but what are your views on this:
    Halfords | Air Conditioning Measure & Charge
    Is this something i should be leaving alone or is it worth a punt?
    2002 S3 8L AMK
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by chazza55 View Post
    I leave the aircon system well alone and let people who have the right equipment work on it.
    I think a regas from a decent garage will cost about £40-£50. They usually hook the car up to a big clover box which removes the old gas, does a pressure test on the system, purges air and moisture from the system and then refills it.
    I while back I got a quote from a VAG specialist for about £100 which included the above and replacement of all the seals on the system.
    Worth doing before it gets any warmer.
    VCDS can tell you if there are any faults on the aircon system - like low pressure. Your fans should kick in when you switch the aircon on. The condenser should also get cold if it's working.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    first thing to check is if the compressor actually engages...
    With the car running switch between econ and auto, and see if theres any change in engine note. The revs should blip momentarily when the compressor kicks in.
    If it doesnt, then its either low pressure, or some other fault like a dodgy compressor clutch or clutch relay, or even a break in the wiring somewhere.
    If the compressor runs but it doesnt get cold, then it probably needs a new drier and a regas.
    TD5 Land Rover Defender build
    Mar 2010
    Kent
    173
    cheers all - will do the checks then take the appropriate action.....best do it before it gets to the crazy hot british summers! ..........well they're hot enough for me so needs to be done.
    2002 S3 8L AMK
    Mar 2010
    Kent
    173
    %$(*&_(%(&^$ is the only way to describe it.
    - checked with my VCDS Lite and cannot connect to the HVAC controller.....only the engine one.
    - took it to be re-gassed.............no luck.......holds pressure ok and no leaks.....but compressor wont work apparently.
    Any bright ideas where to start looking or is it a replacement only job?
    And is it worth getting an ebay one for £100 that has come from a breakers?..........no idea how much audi would charge!
    2002 S3 8L AMK
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    The first time my aircon went boobies up it was the aircon compressor clutch I think. Needed a new compressor and clutch and it cost a lot as it was from Audi.
    When my aircon wasn't working the second time. It was a combination of the fuses (check the three little green 30A blade fuses on top of the battery), the pressure switch and the fan control module.
    There are guides on the Internet for testing the fan control module.
    The fans can be tested with a multimeter to check they're not burnt out.
    I think the pressure switch is a common thing to go wrong - you should be able to see this from VCDS though?!?
    Liam
  1. Slow warm up / running too cold ?
    By pflowers in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2013, 10:30
  2. 1.9tdi running cold wont warm up ?
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2011, 06:46
  3. Heater blowing cold/luke warm
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th January 2011, 19:29
  4. Replies: 0
    Last Post: 27th September 2010, 17:20
  5. Central Air Vents Not Blowing Air
    By silversurfer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th September 2010, 10:37
