Sky InsuranceJMB Retrofits
Results 1 to 10 of 10
    Mar 2012
    Bradford
    56
    Any pics of s3 8l with rstt replicas and 10 or 15 mm spacers??
    Hi guys as above really,not seen any pics of what my car could look like with 10,12 or 15mm spacers with 18"rstt replicas.
    Would love to see some pictures if there is any?
    If not does anybody have any advice on which sizes to go for?its standard brakes but I don't want no hassle with rubbing etc I just want to bolt them on and get the look!
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    18" RSTT wheels
    If you're going to buy any mate, make sure they're genuine. Replicas are just rubbish
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Mar 2012
    Bradford
    56
    Cheers Ben,I already have the replicas,only just bought the car so can't really change them yet,do you know if the offset is different to the genuine ones? I want to go as wide as I can with spacers so the wheels sit flush with the bodywork but without the rubbing? Anybody anymore pictures to show as an example?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    My wheels are et32 and im running 15mm front and 20mm back.
    Fronts are completely flush. Rears are probably in the arch a maximum of 5mm. But my rear wheels have a bit of camber going on so actually looking at my car, the bottom of wheel is flush, just top isn't.
    Sorry for the crap pics. And how my car is sitting, it had just been jacked up
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Mar 2012
    Bradford
    56
    Cheers for that,got a better idea of sizes now,you got any pics of a side view of the car? Do your wheels rub on the arches with those spacers fitted?
    Thanks again
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,561
    10mm front and 15mm rear... on RSTT's as requested...
    <tuffty/>
    Mar 2012
    Bradford
    56
    Cheers tuffty,that sits well but I'm unsure on the offset of my rs tt replicas,do you reckon there same as genuine ones?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,561
    Quote Originally Posted by S3 rpm View Post
    OEM RSTT's are ET33 (18x8), reps are generally ET35... if the reps are 8" wide then they will sit 2mm further inboard than OEM...
    Forge do 11mm and 16mm spacers...
    <tuffty/>
    Mar 2012
    Bradford
    56
    Cheers mate il have a look at them,thanks guys!
    Mar 2012
    36
    [IMG]_utf-8_B_Q2hvcmxleS0yMDEyMDMyNi0wMDAxOC5qcGc=_=[/IMG]
    10"x17" Rear and 8.5"x17" front
  1. H&R wheels spacers-How wide can i go with 18"RSTT ??
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2010, 09:15
  2. Wheel spacers on S3 8L with 18" RSTT wheels
    Last Post: 28th June 2010, 17:11
  3. Pics of your RS4 / RSTT wheels?
    By claty23 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2007, 00:10
  4. OEM RS4/RSTT centre caps on replicas
    By ChriS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2006, 00:35
  5. Are RSTT replicas any good?
    By S2KI in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2004, 18:41
