EM TuningAH Fabrications
Results 1 to 30 of 30
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Question Tell tale signs of a clutch on its way out?
    I'm just curious to know if there are any other signs of the clutch on its way out on these cars? I don't have any slip or if I do its not noticeable, but since I've had the car the clutch pedal has gotten a lot stiffer and ive got to push it down further to change gear as it grinds if I change into 1st/reverse where it didn't before. What could this be signs of? Thanks
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    have you put it in 5th @ around 35 - 40 on a slight hill and floored it? that is a sure fire way of telling if there is a any slip at all. Maybe fluids?
    A3 1.8T Sport (98)
    Fusion Stage 1 Remap
    Forge 007p Recirc Valve
    Stainless Exhaust
    G60 Solid Flywheel & VR6 Clutch
    3 Careful Owners
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Yep, floor it in 4th or 5th from around 3500rpm (i.e. when on boost) and if the revs rise faster than the road speed then it's slipping.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    as above.
    High gear and plant it....the turbo will kick in at around 3000-3500rpm usually...the ref counter will rise and then slip back despite your throttle increase if it is a clutch slip.
    Normally FWD cars clutches will last longer as the wheel would normally spin as a release of the increased torque as opposed to the 4WD S3 equivalent...which tends to send the power to the back wheels at that point which often equates to clutch mash up at high torque figures.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Ah, i can get up a hill in 5th at 30mph easy enough and tbh I can't notice any slip. Just wondering what the cause of the stiffer clutch pedal could be, it got really stiff when audi bled my brakes but then it went back to normal, now its getting stiffer again...
    Thanks for all your replies!
    Audi A3 1.8t AUM
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Pulling away on a slight hill in second was always a good one.
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    has your pedal risen? like has the biting point got higher?
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Quote Originally Posted by Paradox1 View Post
    Hmmm... I'd like to say no, but thinking about it when putting it into first/reverse I noticed that it's different when pulling away so i guess it has! I'm at work at the moment so when I go out to the car in an hour ill pay more attention to the biting point. What could cause this? Please don't say new gearbox xD
    Audi A3 1.8t AUM
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Lol, i have Googled it but I could only find info on clutch slip which I'm sure I havnt got. Just wondering what cause cause these effects on the pedal itself xD
    Audi A3 1.8t AUM
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Theres various methods.
    The clutch in the missus A4 wont slip in 5th gear as described, but if you rev out 1st or 2nd, then hit the next gear hard, it will slip a bit then finally manage to lock up again.
    I imagine its strong enough to stay locked up once its engaged, but not strong enough to stop the slip happening when its already started.
    I suspect as soon as i have it remapped it'll start slipping properly though!
    TD5 Land Rover Defender build
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by Metro View Post
    Our cars usually have pretty low biting points from standard. ive noticed mine has got higher. i've been told this could be a sign of being time to replace your clutch if it hasnt been done before. I'll start buying parts if your in any doubt tbh. You have a 5 speed box so you can fit a vr6 clutch and G60 flywheel. cheap and easy
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Is the vr6 clutch and g60 flywheel better than an oem set up? Is it just a straight swap? Cheers
    Audi A3 1.8t AUM
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    yep higher torque capability and the solid flywheel conversion will give you a little bit more torque. I am about to (when my supplier gets it to me) fit a sachs clutch and solid flywheel as when mine was remapped it slipped in 3rd under boost.. now its starting to get worse
    the pedal getting stiff could be a few things i guess what they are, i dont know lol doubt it will be a new box as the symptoms of selecting reverse etc are signs of clutch failure... it could be fluid related if it isnt really slipping
    and yes it is a bolt off old bolt on new job aswell
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
    dusty's Avatar
    Nov 2010
    nw england
    144
    The clutch biting point getting higher could be a worn friction plate, stiffer pedal could be something to do with the pressure plate, I've just had one of awesomes heavy duty clutches and solid flywheels fitted and can highly recommend these also, my biting point was right up at the top, but I had no slip, since having my clutch fitted my pedal is a lot lighter than before
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Thanks very much for everyone's advice, ill go on eBay and price up the bits. I'd like to replace my cam belt, brake master cylinder because it has a slight leak so i'l get the whole lot done in one sitting with a garage
    Audi A3 1.8t AUM
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Ever get the feeling you backed the wrong horse?
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Hmmm... It's my first car so as much as i didnt want to spend loads on it... I want it to be a bit of a learning exercise aswell. I guess I expected clutch/cam belt to need replacing as the cars done 115k now.. When I get a new car this one's being stripped and turned into a track car so anything I spend on it won't be lost!
    Audi A3 1.8t AUM
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    First and second gear failures on the 6 Speed boxes on older A3/S3 models are a common thing. I think it's the synchros that die. But as it's reverse as well, I would point my finger at the clutch. Although, If you let it continue grinding into first, then the gearbox WILL eventually take it's cyanide pill.
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    try these Darkside Developments - Home
    thats whos sorting my clutch n flywheel out tho not sure about fitting yet.
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Quote Originally Posted by A3 Oly View Post
    Cheers boss ive just checked them out and they seem reasonable! If you find a good place to fit it and it turns out okay let me know as im only down the road from Mansfield.
    Audi A3 1.8t AUM
    Nov 2011
    Newcastle
    214
    To check if your clutch is on its way out or gone...
    Put your car into 4th gear with you handbrake fully on and try to pull away.. If the car stalls or pulls away then you clutch is fine. If the peddle comes all the way up and your still still stationary... Then its your clutch
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    sweet didnt realise. well there is a place in Huthwaite just of a38 called tonks 4x4 now he's a landy guy but he has some nice audis in for servicing he is an old mate so i may see what he can offer. ill keep ya posted.
    not much on the audis but: Tonks Sport | Tonks Sport
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Definitely let me know, only 30mins from me so if they can do it for a reasonable price that would be well worth the trip!
    Audi A3 1.8t AUM
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    On a side note, took the car out this morning and had no grinding at all, very odd! But happy at the same time. No idea how/why but all I can tell is different is that yesterday when I took it out it was 6am and frosty and today it was sunny and warm???
    Audi A3 1.8t AUM
  28. #27
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    Re darkside developments, they are diesel guys but the service i recieved whilst purchasing the clutch was ace and delivery was quick!
    To get it fitted i am looking at 200 inc vat from these guys: Home just off a38
    A3 1.8T Sport (98)
    Stainless Exhaust
    3 Careful Owners
  29. #28
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Brilliant! Thanks for the reply! I'll near that in mind. I need to sort some other things like cambelt first!
    Audi A3 1.8t AUM
  30. #29
    Apr 2012
    17
    How'd you get on with this?
    I've got the same symptoms. Def not slipping and low bite point with crunch in review/first if you don't depress right to the floor.
  31. #30
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    The issue cleared up weirdly, no idea at all and the clutch has been perfectly fine! I did notice that when it was happening it was cold weather, so temperature might have had something to do with it... Had all fluids checked and they were all fine... sorry I cant help any more!
    Audi A3 1.8t AUM
  1. The Best Fairy tale ever!!
    By L1 HCS in forum Jokes, Games & Humour
    Last Post: 18th January 2010, 22:15
  2. A3 1.8 TS Quattro - newbie's tale of woe!
    By russ3ll in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2009, 13:23
  3. Funny signs.
    By james0808 in forum Jokes, Games & Humour
    Last Post: 23rd November 2007, 22:45
  4. what are the signs that you need a new turbo?
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2006, 20:34
  5. Modern Grim Tale
    By necroeire in forum General Chat
    Last Post: 25th February 2006, 22:39
