Badger5Monster Motorsport
Results 1 to 9 of 9
    Mar 2012
    devon
    43
    new engine help?
    the oil pump went on my s3 which has caused bottom end to dry up (im guessing) so im just wondering would a golf gti 150bhp turbo engine lump fit using my gearbox turbo ecu etc so its still running like a s3? if so is it worth doing or to much hastle?
    any help would be appreciated
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    There is a lad up here splitting a s3 as the turbo blew I can give you his number if you want.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by black s3 View Post
    yes the turbo golf blocks will be fine mate...
    Mar 2012
    devon
    43
    yeh the only problem is the s3 engines pick up quite alot of money thats why im after a golf 1, and theres a few around dwn here
    Mar 2012
    devon
    43
    thanks anyway tho
    Mar 2012
    devon
    43
    cheers mate, will it fit in just as easy as the bam lump?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yes you just swap all your gear over to it ...manni turbo and inlet, etc as yours got VVT? if so the head will need changing too, or at least the cams and controller
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    If the Golf engine is an AUM then it will have 19mm gudgeon pins and not the 20mm pins of the S3... try and get a AGU from a Golf/A3 if you can...
    If you have an APY then a BAM engine doesn't have SAI so you will need to do a delete and also change the cam chain tensioner to the non VVT off yours... if yours ia an AMK then the BAM is a straight swap..
    You can use more or less any transverse 20v turbo engine and just mix and match the good bits from yours... 150/180 engines run higher compression ratio than S3's but not really an issue... both Welly and I run higher comp pistons with no issues...
    <tuffty/>
    Mar 2012
    devon
    43
    its the bam engine in mine, do you think its to much work? any rough prices? got a mechanic that will do mates rate
  1. Replies: 4
    Last Post: 2nd March 2011, 12:56
  2. Engine mount details for 2.0TDi BKD engine
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2010, 19:29
  3. 2.8 30v engine, supercharger & Audi s4 engine
    By aposegil in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2009, 10:55
  4. Replies: 3
    Last Post: 10th May 2008, 12:57
  5. Engine is fixed... follow on from engine and turbo is dead
    By PhilR in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2007, 23:10
