    May 2010
    Staines Middlesex
    131
    How to turn idle up??
    For some reason when idling the car is shaking quite a bit have noticed the idles fairly low used to sit on 800rpm now its around 650 any ideas?
    Alais DJA's Avatar
    Feb 2012
    Southampton
    557
    Possible Fuel / Air mix issue
    When did you do a fuel filter change, and injector clean up?
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    What car/engine code? idle doesn't drop out of the blue typically... later DBW ECU's will try to keep idle at the preset idle speed (770rpm iirc)... AGU cable throttle will be adjusted at the throttle body... if you are having idling issues then it could be due to a vacuum leak
    <tuffty/>
    May 2010
    Staines Middlesex
    131
    Engine code AMK. Its intermitant. Gave it bit of a blast and seems to of sorted it out well atleast for the next 5 mins!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Vac leak by the sounds then... does it bounce around a bit? might also be worth doing a throttle body reset...
    <tuffty/>
  1. My Cars winscreen wipers turn on when i turn my light switch on?
    By Mason-A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2011, 21:27
  2. Turn off LED and use turn signal as DRL?
    By xileh in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th June 2011, 14:05
  3. Which way does she turn for you?
    By L1 HCS in forum Jokes, Games & Humour
    Last Post: 21st March 2010, 01:07
  4. My Turn
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th October 2009, 19:55
  5. Turn, click click click, turn, click click click - Whats wrong?
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2009, 17:13
