Results 1 to 7 of 7
    Jan 2012
    128
    Typical parts associated with upgrade to stronger rods and pistons
    Hey currently upgrading my rods and pistons current parts list is
    - Mahle Motorsport pistons- 81mm bore
    - DMF Forged H-beam 144/20mm connecting rods
    - ARP main studs
    - ARP head bolts
    - ARP Crank bolt
    - Calico Coated Bearings
    - Gasket and seal kit
    Any other parts is should order at the same time
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    Not need for ARP's as the standard stuff is very good
    I have just some ARP head bolts ( not stud kit ) and thats it
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Might want to think about new oil and water pumps while you're in there and also a cambelt kit.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Headset kit....oil/ water pump, pick up pipe, tensioners, ....new exhaust guides,,,
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    what comp ratio are the pistons? all the aftermarket pistons i've seen lower the comp ratio
    Jan 2012
    128
    Timing belt water pump tensioner all been ordered thanks
    Jan 2012
    128
    Not sure mate ill ask
  1. how much all in for rods upgrade?
    By Paradox1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2011, 00:24
  2. APU Rods and pistons into an ARY
    By pippo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2011, 16:03
  3. RODS and PISTONS
    By v5 tt in forum TT/TT-S/TT-RS Forum
    Last Post: 21st September 2011, 19:55
  4. TFSI engine parts - head and water damaged block, pistons etc.
    By Adam31 in forum General Automotive Chat
    Last Post: 6th March 2011, 18:07
  5. How much are a 2nd set of S3 Pistons and rods worth?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2009, 23:33
