Volks AutosMonster Motorsport
Results 1 to 15 of 15
    Jan 2012
    Cambridgeshire
    Smile Hello everyone,can you please help me fix my A3 starting problem?
    It's my first post on a car forum so please be gentle! :-)
    I bought a 2001 A3 1.8T at xmas, it has done 128,000 miles, and it has been a bit of a pain trying to sort out a few problems...but thanks to you guys, and the info and posts on this forum, my husband has managed to fix most of the problems but it is still difficult to start the car, it takes 2 or 3 tries before it starts. I would be very grateful for any help you can give me as my husband has run out of ideas.
    He got Vag Com and so far he has replaced speed sensor,camshaft sensor,fuel pump,fuel pump relay,all plugs and coils,coolant temp sender,thermostat,filters
    The problems are:
    1. Bad starting from hot and cold,takes 2 or 3 tries, usually gets running with foot flat on floor and eventually starts
    2. Temp gauge doesn't work, never moves but Vag Com log shows it stays around 90
    3. Remote central locking doesn't work, we have tried lots of different techniques and none of them work, we only have 1 key
    Vag Com Faults left are:
    16725 - Camshaft Position Sensor (G40): Implausible Signal
    P0341 - 35-00 - -
    01366 - Opened Due to Crash Signal
    35-00 - -
    The cam sensor has been changed so don't understand why that is still there (could be a duff new sensor?) Would this cause the bad starting?
    Does the Crash Signal cause any problems?
    Please help if you can as I use the car for school run and it is very embarrassing trying to start it! I love the car and my husband likes it too (even though he is a Toyota fan) so I don't want to give up on it
    Best wishes from Cherry :-)
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    has the cam belt been done recently (128k)? just wondering if the cam timing is out?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Have u checked the starter motor? Has the car ever been modified by a previous owner? Sometimes disconnect the battery and let it reset itself might help
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    cam sensor, broken wire, done a continuity test ?
    have you tested the instrumental panel to see if the the gauge thats broken rather the sensor its self
    when you say C/L doesn't work is that remote or key in the lock ?
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Failing that could be a bad or faulty maf or bad battery
    p
    Jan 2012
    Cambridgeshire
    Thanks for all the quick replies :-)
    Don't know whether the cambelt has been changed recently,it was on my husbands list of 'things to do' :-)
    The Starter motor makes a lot of noise after it disengages, but seems to turn the engine over ok, the battery has been replaced (forgot to mention that) and my husband says he has disconnected it each time he fitted something new to the engine, no idea if it has been modified in the past but service history is very poor and lots of entries missing :-(
    Will get hubby to check the wiring to the cam sensor, hopefully he wont do more damage!
    The Vag log showed the temperature was steady around 90 ish so must be the instrument panel, can the gauge be fixed somehow?
    The central locking works with the key in the door no problem, just the remote that doesn't work
    Thanks very much for all your replies, hubby has a few jobs for tomorrow :-)
    Cherry
    Nov 2011
    Newcastle
    214
    Id say the starting motors worth a look at. But as Jay said you should check the cam sensor wires.
    If vag com says the cars running at 90 then id say its the gauge thats faulty.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    dead battery in the key? might just need to be re-programmed if its had a loss of power for a while
    you can do a dial test with vag com to check the gauges for full movement and to test to make sure they work correctly
    the gauge would depend if its broken on the PCB or the wiring from the sensor
    common problem for the starter to stick
    Jan 2012
    Cambridgeshire
    Do the cam sensor wires all run from the sensor to the ECU? (Hubby is asking questions from his groove in the sofa!)
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,234
    should be a 3 pin connector.
    1 wire will be the ground
    1 will be a reference feed
    the other will be the signal wire to the ECU
    i haven't got a wiring diagram to hand to tell you which wire it will be
    Jan 2012
    Cambridgeshire
    Thanks Jay we will test the wires and let you know how it goes :-)
    Also forgot to mention that the car is a bit slow to accelerate from low revs but we assumed that was because of the cam sensor fault?
    Will definately change the cam belt asap!
    Thanks guys
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,342
    Welcome to ASN Cherry. Hope you enjoy the forum. The guys/girls are all really knowledgeable. Enjoy.
    Nov 2011
    Newcastle
    214
    The cam belt wont change anything. Itll only cause a problem if it has been changed recently and the timings a tooth out (as Alex C said)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    It will have had the cams out at some point, The cam to cam timing will be wrong i expect. It causes it to be harder to start and cough up this fault code. I bet the car has a VVT tensioner on it. WHat engine code is it?
    Jan 2012
    Cambridgeshire
    The engine code is AUM, thanks for the info that sounds most likely then, can't wait to get it sorted out :-)
  1. idle problem fix
    By karls s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2014, 19:39
  2. A3 coolant level sensor problem and fix
    By zebrathreee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st November 2011, 18:08
  3. How can I fix this paint problem
    By mikeyw in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st June 2011, 06:42
  4. possible starting problem
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2007, 20:28
  5. air bag problem on potential new a4. is it easy fix?
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2006, 17:54
