Results 1 to 13 of 13
    Feb 2012
    1,102
    notchy gearchange s3?
    Hi guys. since owning my s3 i hqve joticed that the gearchange isnt exactly smooth. from doing searches i see most people are saying that the s3 is a bit like that from factory but my first s3 that i had was spot on. in fact the first memory of the test drive was how smooth the gear selection was. so whats the right one on this? i also have a friend that says you can re set the alignment or something? anything on this would be great as always guys thanks. daz
    Jan 2011
    Glasgow
    233
    Mines the same real bad cold in 2nd mostly.
    S3Zek's Avatar
    Sep 2011
    407
    Fresh oil in the box may help a bit, it did on mine anyway...
    Feb 2012
    1,102
    I thought the gearboxes were sealed? i read that an r32 shifter shortens the throw a tad and makes it a bit smoother. although only by one person. there 22 quid so might just try.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Mines abit notchy in 2nd! Spoke to jody at midland VW who said they typically like this, nothing really wrong, just how it is when cold. Whe it's warm it's lovely!
    Feb 2012
    1,102
    Mine is never lovely lol. ill get my mate to try this re adjustment anf ill fit an r32 shifter and report back. thanks guys!!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    ive had 2 6spd now and both of them have been really poor and knotchy also specially 2nd gear oil didnt really make any difference at all tbh....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Feb 2008
    2,817
    As said changing the gearbox oil helped mine. Saying that think I need to change again. Typically worse in the autumn and winter secondary to the cold weather.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Jan 2011
    Glasgow
    233
    When I say notchy in 2nd there is times it will refuse to go in... Better once warm then it's just notchy. 1st is notchy to not as bad. Rest of the gears are fine.
    Oct 2009
    90
    Try new dogbone mounth bushes, they are cheap as chips and certainly helped my gearchange. Just make sure you get the red Powerflex ones (for diesels).
    POWERFLEX GOLF MK4/BORA TDI ENGINE MOUNT DOGBONE BUSH | eBay
    Currently running a MTM stage 1 map, ECS brakes, Forge DV, Bager 5 TIP, 18" RS4s, Bilsteins, H&R springs, Tie bars, Milltek catback... but not for long...
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    I run the diesel dogbone bush and the R32 shifter and the shift is still OE but miles smoother. I'm not saying it'll solve your problem but it certainly helped smooth my shift.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Jan 2011
    Glasgow
    233
    is it a millage thing? or the box's just poor from new?
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    When I first got my s3 mine struggled To go in 1st and 2nd sometimes when cold. I've since then destroyed that one and had a recon box fitted.
    Which I have absolutely no issues with. Smooth in and out of every gear. Every time.
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
  1. Gearbox Notchy??
    By SteveSAS in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2011, 07:40
  2. ANYONE GOT A NOTCHY BOX
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2010, 09:37
  3. Notchy gear change?
    By phantom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2009, 23:44
  4. Jerky gearchange
    By Monsoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2008, 16:45
  5. Notchy Gears -Normal or what ?
    By Spin140 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th May 2007, 12:57
