Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Dec 2010
    Newcastle-upon-tyne
    93
    Slotted abs disk
    My sister's A3 has just had 2 new front wheel bearings done at a garage run by monkeys. They have warped the ABS disk which means the light is on. Where can I buy new ones and how much are they? if its Audi only part, gonna get the garage to stump up for the cost.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,609
    They normally only come with a new hub tbh... VAG may sell them seperately but suspect it will be a hub or nowt
    <tuffty/>
    Dec 2010
    Newcastle-upon-tyne
    93
    Looks like the garage is stumping up for a hub then!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    the abs disc screws on iirc
    Aug 2010
    1,540
    Quote Originally Posted by Byzan Photography View Post
    mk3 golfs/corrados with abs definaly screw on with 3 disc type screws thru the hub.
    more than certain these are spot welded to the hub.
    how do you know its the sensor rings? is it coming up with a sensor fault but the light doesnt come on till its been driven? is the abs chattering/cutting in as you come to a stop?
    its very common to bend the rings tbh. when you press the hub out of the bearing the inner bearing race sticks on the hub, and cus of the sensor ring its a total ballache trying to chisel it off!
    i get the grinder out and grind thru the race as much as i dare then chisel it, first hit and it cracks thru where its been ground away and just about falls off.
    Dec 2010
    Newcastle-upon-tyne
    93
    I assuming its the sensor ring. It was fine, went into the garage, ABS light is on, the ring is bent. I dont know if it was bent before or not, but it seems suspect.
    Edit: It seems to be testing itsself when driving, then the light comes on after a bit. The pedal is juddering when braking. After a minute or two the light comes on then it stops. I had replaced the sensor not too long ago so I'm ruling it out. Unless they have damaged the sensor when changing the bearing.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    scan the car see what code you get
    Aug 2010
    1,540
    sounds like theyve damaged it. take it back and kick off.
  1. Disk size
    By MarkTweedley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2011, 21:22
  2. ABS & Traction Control Light On... ABS Not Working
    By Gibonz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2010, 09:32
  3. rear disk - abs rotor
    By splasher in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd May 2010, 19:17
  4. wat kind of drilled slotted Brakes should i get
    By 97_A4_1.8Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd October 2007, 17:10
  5. Drilled or Slotted thats the question?
    By Tweaky in forum General Technical / How To
    Last Post: 23rd February 2003, 00:21
