    Sep 2005
    Derbyshire
    180
    Wing Mirror fitting
    Hi Guys,
    So a week or two ago some *undesirable person* decided my passenger side wing mirror was a football and decided to kick the backside off it until it broke.
    Now unfortunately it smashed the plinth that holds the mirror onto the housing (thats attaches to the door), meaning I have had to buy a complete mirror off the 'bay.
    My question is, in order to fit the new mirror, is it simply a case of remove door card, disconnect mirror wiring, remove 1 screw and remove old housing then fitting is the reverse of removal?
    Or is there something else I need to be aware of?
    Car is a 1999 Audi S3.
    Thanks!
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Hi dude, iv got some good news, no need to take the whole door card off, just undo the screw on the door card and pull the top by the mirror and remove the littl black piece of plastic which will reveal the(i think 2 alankey bolts and connector) hope that helps, its a straight forward job.
    Sep 2005
    Derbyshire
    180
    Cheers Camscockle!
  1. wing mirror - shorter passenger mirror
    By whothafunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2011, 11:39
  2. Wing Mirror
    By philyus in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 9th December 2010, 10:38
  3. Fitting Wing Mirror Caps
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2010, 21:41
  4. S3 wing mirror base fitting problem!
    By Chlippo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2010, 13:49
  5. Wing mirror removal/re fitting
    By b00zehound in forum General Technical / How To
    Last Post: 6th May 2009, 17:11
