AH FabricationsJMB Retrofits
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: 3" Downpipe fitting!
    Mar 2011
    Argyll, Scotland
    69
    Smile 3" Downpipe fitting!
    Well all i can say is hopefuly i never have to do that again. Started at 5 at headed home at 12! Could def be done alot quicker next time round bout what **** of a job. Thanks to tuffty after searching some posts. I had to laugh though, after deciding the only answer was to destroy the flexi to split the pipe in two, i cam across my air chisel, then read thats exactly what tuffty had done haha.
    I had a bit of a time trying to find the best way to do it, so heres a quick how to from my tired mind.
    o/s whell of and you will be able to see the 3 nuts to the turbo, and remove the drive shaft to allow access.
    I got 2 from the arch and 1 from above.
    Grind of the bolts connecting the DP to the Cat and seperate.
    Sounds brutal but hack the flexi on the DP until you have 2 DPs and pull the bottom out the bottom and the top out the arch.
    Loosen the sub frame and dogbone to allow movement and the 3 bolts for the prop shaft nd move to one side.
    This the allows you to put the new DP through the bottom and into place.
    Then its pretty much a reverse procedure.
    If i have forgotten anything feel free to add. Apart from that, im very pleased with it, can really hear the turbo now
    deeman88's Avatar
    Watch this space...
    Aug 2011
    SE London
    418
    sounds like you had fun there mate! But congratulations for doing that. Downpipes are a pita thsts why i put mine away for a few months ghen did it with a new turbo, decat, silicone tip and service... overnight
    My Build Thread... Nothing too special
    Mods: ASN Sticker on Rear Driver Window, Forge 006, KO3s Turbo, Silicone TIP, 3inch Downpipe, Decat, FK Coilovers, Bosch Aero Retrofits, NGK 6458 Sparkplugs.
    To do : Front and Rear 25mm ARB, Strut Brace, Adjustable Droplinks, Poly Red DogBone, Remap, FMIC... to be completed
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    thanks!
    is it really nessesary to loosen the subframe? does it give you that much more room?
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by krisrg87 View Post
    Imagine the fun when its Quattro and there's a prop in the way
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,568
    Quote Originally Posted by Alais DJA View Post
    The OP's car is an S3 mate...
    <tuffty/>
    deeman88's Avatar
    Watch this space...
    Aug 2011
    SE London
    418
    I didnt have to undo my subframe btw, and for the quattro boys... 2 words- good luck! Lol. Its a pretty tight job as it is and doesnt need anymore parts restricting access
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    <tuffty/>
    Urgh, nobody likes a challenge anymore! I remember the days of putting v6's in MK2 golfs,
    KO9 lumps in Mk1 civics.
    Skyline engines in Mustangs.....
    In all fairness thought, they do "make" a proper de-cat for the S3. Us poor TQS who couldnt afford the S3 ( apprantly )
    Evo in September, cough, cough
    They are indeed a P.I.G
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,568
    The S3 is the tricky one... K03 cars are much easier including the TQS A3...
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    If you think getting an OEM downpipe out is hard, try fitting one. Not a fun job.
    Homer Simpson
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,363
    Dead easy on a ko4 FWD A3 boys infact, it's all easy!
    Ko3/s FWD downpipes are a walk in the park, ko4 wasn't much harder.
    Who needs a haldex anyway
    muhahahahahaha.
    Insert angry comments here \/ \/ \/
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,568
    muhahahahahaha.
    Oes noes!!!! Prawn has inherited the Jardo gene!!!
    <tuffty/>
    krisrg87 likes this.
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    <tuffty/>
    I agree,ive changed three engines in my time and two clutch's,fittin xs power mani hybrid,i can honestly say is the hardest thing ive done,basterd tranverse engines ah!
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,363
    he came to see me this morning, I think it's rubbed off. Think I want a volvo now
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I hate you. Imagine how far I wouldn't get without the good old Haldex! lol
    Homer Simpson
    Mar 2011
    Argyll, Scotland
    69
    Thanks for the replys. Yeah the haldex made it difficult to say the least but i still wouldn't have it any other way!
    Welly if someone asked me to fit a oem dp i would kindly tell them where to put it.
    Superkarl, i found there wasnt any other way then loosening the subframe, it was very easy though, just 4 bolts. It dosnt move that much but its enough along with moving the prop shaft, Good luck.
  1. 3" Downpipe - Fitting Instructions?
    By Piester in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2011, 00:06
  2. ebay 3" downpipe and decat fitting - Is it hard?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2010, 23:08
  3. downpipe fitting.
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2010, 01:18
  4. Downpipe fitting
    By s3 ryan in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2009, 12:36
  5. Downpipe Fitting
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2007, 14:44
