    Andiz's Avatar
    Jan 2011
    Sheffield
    33
    limp mode question
    my S3 has been running fine until the other day when my water pump died im due to change it along with the timing belt tomorrow but for some reason it has also gone into limp mode and the only fault showing up on the vagcom is the abs and the cooling system. The abs has been on for a couple of weeks without limp kicking in but could the cooling system bring on limp mode its only boosting to 7psi and it is normally 25psi, any ideas?
    Andiz's Avatar
    Jan 2011
    Sheffield
    33
    Problem sorted it was my boost controler playing up with a loose pipe :-)
  1. Limp mode
    By A4_MO in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th February 2012, 10:45
  2. limp mode?
    By audi_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2010, 21:16
  3. Limp mode - help?
    By ickleric in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th October 2008, 12:47
  4. How do i know if im in Limp Mode?
    By Nogwuy in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st July 2007, 18:56
  5. Limp Mode
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2005, 09:55
