Results 1 to 7 of 7
    ptr
    ptr's Avatar
    Aug 2010
    129
    Hoping someone can help - central locking and windows no longer work!
    This all happened at once, car was perfect then windows, sunroof and remote locking stopped working. I've been googling and searching but have yet to find something displaying these exact symptoms;
    - Central locking no longer works, indicators don't flash, it's like I havent even pressed the button on the key fob.
    - Electric windows and sunroof don't work - again just dead.
    - If I lock with the key, the alarm does arm - ie. flashing red LED on the door
    - If I press the lock button on the driver door nothing happens, no motor noise from the central locking pump.
    VCDS shows a central locking pump leak and nothing else, I've cleared this and it comes back straight away.
    Is this simply a case of replace the central locking pump (as it contains the convenience ECU which controls windows/sunroof as well)? OR is this a wiring issue somewhere as it almost seems like the central locking pump is getting no power or is dead? (I've checked fuses).
    Also, I checked the pump and theres no water or obvious damage around it. Hoses and wiring appear fine.
    Apologies for the long post, really hope someone can point me in the right direction - is it worth replacing the central locking pump first?
    Pete
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,500
    Maybe a pm to NHN?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Do the doors lock with the key and does holding the key in the locking position close the windows/sunroof?
    Scan for fault codes is top of the list...
    <tuffty/>
    Mar 2011
    Argyll, Scotland
    69
    I had the exact same problem. I would advise removing the central locking pump, very easy to do. Open it up and and the is a graphite disc/impeller. Mine was shattered and had blown the fuse. Windows/central locking and interior light is all on the same fuse. If it is this part then you can get a repair kit of ebay for £40. Mine works great now. Good Luck
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    +1 on that. Central locking pump. Had to replace mine last week for same reason. Might just need to be vacuumed out though. Try first. Unplug from behind rear passenger side light and dismantle. Don't worry it's only a circuit board and punk etc. if not. eBay for new one. I paid £58, but you'll need someone to reprogrammed the keys to the central locking after install.
    Also, check the fuses. Top right one from memory.
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
    ptr
    ptr's Avatar
    Aug 2010
    129
    In case anyone else has this problem, I got a used central locking pump off eBay for £60 posted, fitted today and everything is working fine!
    Pump runs for approx 2-3 seconds and after clearing the 'pump overrun - likely leak' code it has not returned so no leaks hopefully.
    I had to resynchronise my keys, here's how;
    To clear central locking memory put one of your keys in ignition and turn it on but don't start engine. After that get out of your car and with second key lock your car (not with remote), keep the key in the lock and slowly press the unlock button 5 times on your remote. The indicators should flash each time you press unlock - the memory has now been cleared.
    Open your car with a key and take out the one from the ignition and close car by key. Wait about 1 min and open car, put one of keys in ignition and turn it on but don't start the engine (I've read that you need to remove the fob and just use the key for this, I did, but not sure if it's actually required). Leave this key in the car and get out.
    Lock driver door using the other key (this is the one you're programming) and press the unlock button once with the key still in the lock, the indicator should flash once. Wait 15 seconds then press and hold unlock for confirmation, the car should open. This key is now programmed, remove the other key from ignition to test.
    Do the same for other remote, but when you program this one you have to press unlock twice and again wait 15 sec and press unlock once more to confirm.
    Credit from this forum;
    Audi A3 Key Fob not working !!!!! I just tidied up post #6 to hopefully make it easier to follow.
    Jimgrim77's Avatar
    Nov 2011
    957
    Glad you got it sorted.
  1. No door locking, windows shutting, central locking, would that be the answer?
    By Nuno_rules in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2012, 15:12
  2. central locking and electric windows please
    By 20v-turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2012, 11:42
  3. Central locking and windows not working
    By betamike25 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2012, 16:20
  4. Central locking & windows
    By Rikster23 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2009, 21:43
  5. Central locking along with all electric windows!
    By mitalm in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2008, 23:53
