EM TuningSky Insurance
    S3Rich's Avatar
    Aug 2011
    sw London
    31
    stock inlet manifold
    Quick question guys.
    Can a stock AMK inlet manifold be ported to the size of my new AGU head, rather than using the transition spacer small->big,
    ive opended up a casing on a 2stroke scooter to accept a oversized barrel and piston,with the help of a die grinder and dremmel.
    7hp ---- 30+hp i know it small stuff but its where i learnt.
    1.can it be done
    2.has it been done
    3.would you do it
    cheers
    rich
    Silver and red, 210 AMK, AMD Remap, Ah fabs FMIC, B5 V1 3" intake with heatshield, Forge Silicone pipework boost/breathers, 007p,phenolic inlet manifold gasket,stack boost gauge and a few more bits..... 215 g/s @ 22psi vag-com logged
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    You can port match it to the gasket as the runners are slightly smaller but i dont think theres enough metal to allow you to open it enough.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    No gains to be made by doing it, just bolt on the inlet
    The rest of the port really needs to match the head, thats why i built a AEB running inlet with Excessive plenum
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,026
    The small port inlet hasn't got enough material to open up to large port size and there is no benefit to doing so... easier to just use a transition phenolic and get the benefits from that..
    So...
    1.can it be done...
    No...
    2.has it been done
    No...
    3.would you do it
    No...
    SEM or what Andrew has done... its what I plan to do and tbh both Welly and I run std inlets currently on big power with no real issues... to gain you really need the larger plenum of the SEM or xcessive to make gains over the std inlet...
    <tuffty/>
    S3Rich's Avatar
    Aug 2011
    sw London
    31
    cheers everyone,ill start saving for the SEM then but thats deep down the list.
    Jun 2009
    Leeds
    3,353
    Custom will be cheaper
    May not give you as much bhp as a sem one
    FOR SALE
  1. s4 inlet manifold
    By jutlis 3.0 in forum For Sale/Wanted - Audi Parts
    Last Post: 17th February 2012, 19:44
  2. Inlet manifold?
    By vince, A3 turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2011, 07:40
  3. S3 inlet manifold
    By S3 AJ.X in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 17:19
  4. Inlet manifold (A3,S3)
    By emery1990 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2009, 20:22
  5. Inlet manifold help
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 10:06
