Volks AutosChris Nott
    codemonkey's Avatar
    Mar 2012
    Rochester, Kent, UK
    Smile Rear washer jet broken
    Hi there, name's Paul.
    First time poster but it won't be my last. I intend to stick around, learn & help, as you all are. Anyway...
    I bought my '98 A3 1.8T in December 2011. All looked find when we inspected it, but upon close inspection at AMD Essex (a well respected tuning company) at a full service, it needs a load of little things which I'm slowly getting through. All age related issues, but there's one that looks like a lot of work.
    The rear washer jet is broken. At first, it worked ok but a couple weeks after buying it, it stopped working. AMD say the pipe is broken, somewhere between the fluid bottle under the bonnet and the jet on the boot lid. Just wondered if anyone has ever replaced this and how much work it it?
    '98 A3 1.8T. Stock as the day it was made
    Jay A3's Avatar
    come fly with me
    Mar 2011
    Greenhithe, Kent
    1,789
    welcome paul
    Its a process of elimination.
    When you push the rear washer lever can you hear the water bottle motor running? If yes then could be a blocked or loose pipe somewhere along the line. I had a similar issue, turned out that the pipe to the rear motor had popped off, Easy fix by taking the boot lid cover off.
    There is a thread on here showing with possible causes and checks you can do
    heres-why-some-peoples-rear-wash-wipe.html
    Good luck
    <Jay A3 build thread>
    241bhp K03s - R Tech
    codemonkey's Avatar
    Mar 2012
    Rochester, Kent, UK
    Hi Jay, it does make a noise but nothing comes out, so I'm sure there's a pool of water somewhere! I'll take a look under the boot lid tomorrow, and report back.
    Thank you!
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    Ok it it's connected at the boot wiper side and your not seeing any water anywhere the place to look is in the plastic loome/ wiring housing ( not sure of it correct name) like black plastic trunking... its a bit of a pita but could cause you ££££ if its there and not sorted. Need to remove air box as it's underneath it, that's how people usually miss the leak then end up replacing fuse boards if lucky.
    Happy hunting lol
    Keiran's Avatar
    Dec 2011
    Sheffield
    91
    +1 ^^ as mine did the same I plugged the hoses back together but still nothing. It was also disconnected in the left hand side of the boot and was filling the rear arch up with screen wash. Luckily there was a rubber drain plug
    G60DAN's Avatar
    Cornwall
    321
    Hello and welcome to ASN there is a join round the sub in the boot that's where mine poped off just push it back in and taped the s**t out of it.
  1. Rear washer jet
    By G60DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2010, 21:39
  2. rear washer jet
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2007, 13:37
  3. Rear washer jet is weak
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2007, 19:43
  4. Rear washer jet
    By Hotscar in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2007, 08:23
  5. S3 rear washer jet problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2004, 15:34
Tags for this Thread
