Results 1 to 11 of 11
    Med performance's Avatar
    Mar 2012
    Wrexham
    Follow Med performance On Twitter
    Central locking pump or recoding keys ?
    My 2 keys have decided to stop working, replaced the batteries Still don't work ? The doors will lock with the button on the drivers door does that mean the pump is ok or still faulty ? Do the keys need to be recoded if so can it be done at home in the ignition with different button presses or dealer
    Apr 2009
    7
    Have you checked the fuses? They are F6, F14, F37, F38, although in my own experience the problem is probably the shattering of the graphite impeller inside the pump itself, which sounds bad, but it really is a pretty easy fix. You can either source a new graphite impeller, or do what I did and just replace the motor inside the pump, also doing this means that you do not have to reprogramme the keys. The motor can be found here: AUDI CENTRAL LOCKING PUMP REPAIR KIT 8L0 862 257 | eBay
    Aug 2011
    160
    If both doors lock using the inside button on the drivers door then it sounds like the pump isn't at fault.
    Audi A3 1.8T AUM Sport with more doors.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Try unlokcing the car with the key then pressing the buttons on the remote.
    Sometimes that will resync the rolling code without having to fully recode the key.
    Otherwise:
    Audi A4 (8D) Central Locking - Ross-Tech Wiki
    TD5 Land Rover Defender build
    Feb 2012
    54
    I has an issue with my central locking mate and I found a how to on ehow.com and that worked where everything else didnt. I posed the link in another thread.
    Mar 2012
    Wrexham
    Quote Originally Posted by s3-oz View Post
    i tried the ehow one but it says press the door lock button with the ignition on but the door lock button only works with the engine started, the pump just makes a noise with just the ignition on could it be shagged ?
    Feb 2012
    54
    Can't remember how it worked mate, but I can honestly say I tried EVERYTHING else and nothing worked. Tried this, and actually got to I think the 4th step and being a numpty couldnt see any lights that were meant to flash (I was in the car so obv didnt see the parking lights haha) and I ignored it got out and went into Tesco's, came back out and pressed the button for some strange reason and BAM the central locking was working
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    put one key into ignition and turn but don't start the engine.
    Then come out of the car and using another key close the door using key. After 2 sek press open button.
    It should work.
    Currently not in the country
    Mar 2012
    Wrexham
    Do u turn the ignition on till all the lights come on the dash which I think is 2 turns or just one with no lights ?
    "Stick a V8 in it!"
    14,900
    Lights on.
    Did you not read the link i provided to these instructions on Rosstechs wiki?
    Mar 2012
    Wrexham
    Sorry I thought it was only vagcom
  1. Recoding central locking
    By chud in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th August 2011, 10:31
  2. central locking pump
    By johnsykes in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th April 2011, 20:01
  3. Central locking pump
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2010, 19:29
  4. where is the central locking pump
    By Boggle in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 12:30
  5. Central locking pump help
    By floyd 1.8 turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2009, 17:30
