EM TuningBadger5
Results 1 to 12 of 12
    Dec 2010
    17
    A3 1.8t won't always start and when it does it stalls after a few seconds
    Hi,
    Iv got a preface lift a3 1.8t that has been left for a few weeks and the battery is just about flat so I have tried jump starting it and it just cranks over for ages and after about 5 attempts starts but dies after a few seconds and will not restart.
    I have tried leaving it for a while before trying again and I get the same problem.
    Have also tried a new battery that I know is good in it and have had no luck.
    Has Anybody got any ideas of fixes?
    Nov 2011
    west sussex
    131
    I had this turned out it was fuel relay they have two relays a cheap ten quid one and the more expensive 40 quid one and guess what one fixed it was the 40 quid one! Try that fixed mine
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Have u tried running a vagcom check mate?
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    Nov 2011
    west sussex
    131
    Don't show up if it same as mine guy who works for aa told me common problem he found with the 1.8 engines
    Dec 2010
    17
    Hi, iv scanned it with vag com with no luck and used my autel maxiscan vag 405 and that didn't show anything really just a radio ariel code.
    Baby audi where did you get your relays from?
    cheers tony
    Nov 2011
    west sussex
    131
    Erm gsf don't use eurocarparts I got sold wrong ones twice and gave up plus they 5 quid more expensive! Hope it works for u too
    Nov 2011
    west sussex
    131
    Bro did fix work
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Fuel filter....
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    can you hear the fuel pump under the rear seat? try banging it and see if it fires up, if so you will need a new fuel pump...
    Nov 2011
    west sussex
    131
    If it was like mine den yes I can hear it
    Dec 2010
    17
    still not having much luck with this guys.
    ran diagnostics on it again today and came up with a few fault codes these were
    01249
    01250
    0151
    0152 which are all injector shorts to ground
    01247 charcoal filter solenoid valve
    01262 solenoid valve boost pressure short
    I have brought a fuel pump relay from GSF (£40ish) but when i came to fit it it didnt match up with any of the relays in my relay box, i have got relay numbers 53, 387, 382, 53 (installed on its side), 100, 167 (installed upside down), 377 (installed upside down)
    can anybody shed some light on this please or is it time to throw it at a garage and see if they can sort it out. the car will only turn over now will not fire at all.
    Many thanks for any help Tony
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,472
    Sounds like a wiring fault to have brought up all those codes...
    s3gazz had a shed load of sensor faults and it turned out to be a wiring issue with the MAF... the plugs fall apart so could be worth looking at that..
    Its something sharing a feed to all those sensors that causing the issue... find that and I would imagine they would all go...
    <tuffty/>
  1. 2.0T FSI rough start up and misfire for first 2 seconds ???
    By ahed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2012, 20:54
  2. a rattle sound on start up but only last a few seconds
    By harvey01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2012, 19:42
  3. Replies: 4
    Last Post: 8th October 2011, 18:22
  4. 3.0 tdi clatter for 5 seconds on start up
    By mudzs in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th August 2009, 18:11
  5. A4 stalls 2 seconds after cold start?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2004, 17:03
