Sky InsuranceChris Nott
    talentwalsh's Avatar
    May 2010
    Galway
    139
    ABS/ Braking problem
    More S3 woes..
    After about an hour of driving the esp light started flashing the the car felt like it lost power so I decided to pull over. But on pressing the brake the ABS was going mental and you could hear grinding and buzzing noises, sounded like the abs pump wanted to eat itself!! Tried to drive off again but when I went over 20mph the same esp light came back on again. Turned the car off and let it sit for a while and it was fine again. The only codes that came up were 01130 ABS operation fault and brake light switch intermittant. Could it be related or has anyone had this problem before?
    The car is a 01 S3 AMK by the way
    Jan 2011
    northants
    165
    put a brake light switch on car first
    then retry
    cancel faults and roadtest then recheck fault memory
  1. Braking problem
    By bmimily in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2010, 12:17
  2. ABS kicks in under no braking
    By Joe_i in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 23:46
  3. A4 S4 B5 - ABS & ESP lights are on since driving and braking over ice??
    By S4DemonGreek in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2010, 19:55
  4. A3 braking/abs light problems any advice please?
    By craigd in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:10
  5. S3 BRAKING PROBLEM
    By builder al in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 09:18
