Chris NottSky Insurance
Results 1 to 13 of 13
    Apr 2010
    168
    air leak when pressing the brake pedal
    Hi guys,
    My car alarm was going off non stop and the mrs couldn't stop it while i was away so because of that, the battery died and subsequently the car sat for 2 weeks with no power. I jump started it when i got back and all was ok, apart from the brakes.
    I think the above is a red herring because i don;t think a flat battery could cause this.
    Basically, when i brake, there is a hissing noise coming from around where the brake pedal is in the car, and the brakes don't really feel spot on. I've read on the forums about brake servo's, vacuum hoses etc, but i'm not really sure which one to look for as different people have had different experiences.
    Basically, the hissing noise only happens when i'm pressing the brake pedal, for the first half a second or so. If i pump the pedal, it does it everytime for the first half second on each pump. it does NOT hiss when the brake pedal is not being used.
    Brakes are obviously a biggie on cars and i don't want to mess around with something unless i know what it is for definate. The garage that does all my work doesn't seem to think it's an issue however i do as the brakes don't stop me as well as they used to (standard brakes btw).
    Anyone got any suggestions as to whether it could be a hose, and if so which hose/where is it?
    Mark
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Brake piston valve - had a mk2 golf that did the same thing....could possibly be the same
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    I'm sure most cars will hiss slightly when you press the brake due to the servo. You cant normally hear it with the engine running etc though.
    TD5 Land Rover Defender build
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Mine does the same thing. Always has. Could check vacuum pipes to the servo. I replaced these but it still isn't any better. Think it may be normal?
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Apr 2010
    168
    I can definately hear it when the engine is running and i'm driving. Like i say i've never heard it doing it before so wondering if it could be a vacuum hose or something?
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    does your brake pedal feel harder?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Apr 2010
    168
    No the brake pedal feels a lot softer
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Quote Originally Posted by m8arx View Post
    Hi guys,
    Mark
    I had the same sort of problem ages ago and made a thread:
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/114807-not-my-day-today-hissing-brake-pedal-now.html#post1194807
    I bought a new servo but then found out i was a right pain in the a*s to change. Then i found out on another forum that if you spry some silicone grease down the inside of the gaiter with the engine running and the same time as you pump the brake pedal it can fix it.
    A week now and its still going strong (famous last words...lol).
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    Apr 2010
    168
    Cheers a3t, but you seem to have a hissing sound when you're not pressing the brake and it stops when you press it if i'm reading your thread correct? Where did you spray the silicon grease into and who told you to do this?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,018
    Yeah but i figured it must be the same seal making the noise.....lol
    I read it a while ago but i think it was this thread:
    http://www.vwt4forum.co.uk/showthread.php?t=6541
    James333's Avatar
    Dec 2007
    227
    I have the same issue, if you look at ELSA, it seems it is an expected problem as the remedy has its own section....
    If it is anything like mine, there is a suction type woosh noise when you press the brake, I think it does it with the engine off too. I am fairly sure it is not a vacuum leak because if I switch the engine off and wait 5 minutes, when I apply the brake, it is still servo assisted suggesting there is no leak in the system as it's holding the vacuum. I came across the fix by accident but basically it says. The drivers side luggage compartment needs to be removed and there is a rubber boot (very similar looking to a CV boot) that fits over the push rod going into the servo from the pedal, when this comes off, you get the noise. Re fitting this should solve the issue
    I'll get on elsa now and see if I can paste the page on here!
    2001 AMK S3 Custom Code stage 1, B5 TIP, Jetex filter
    James333's Avatar
    Dec 2007
    227
    James333's Avatar
    Dec 2007
    227
    These may help? The problem on mine is caused by the bellow numbered 20 in the first picture.
  1. Whooshing noise while pressing brake pedal hard and engine running rough
    By SuperPuper2000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2011, 11:35
  2. Clutch Pedal and Brake pedal problem
    By Neesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2010, 08:25
  3. Replies: 5
    Last Post: 20th May 2009, 14:23
  4. Brake pedal travel after brake upgrade!
    By Stevie C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2008, 17:48
  5. Brake pedal seems to be bobbing up & down!?!?!
    By imported_razputin in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2005, 09:28
