Chris NottEM Tuning
    Jan 2012
    Misfire when cold, when warm, misfire on WOT
    My 2001 S3 AMK has been giving me troubles over the last few months.
    Previously it was randomly misfiring, so on advice from the forum, I've checked for vac leaks and fixed the coil wiring.
    I've fixed a split pipe and replaced the thermostat, temp sender, and had a known working set of plugs/coils fitted.
    After all this my misfires only seem to happen now when the engine is at less than 90deg C temp or when @ 90 under WOT.
    I assume that I still have a VAC/Boost leak.
    What should I check? Also what blocks should I monitor in VCDS/VAG COM to aid in diagnosis.
    Any help is appreciated.
    Jan 2012
    Just an update, as soon as temp reaches 90degC(in VCDS) my misfire stops.
    So what VCDS blocks should I be checking?
    Jan 2012
    OK, so i've checked block 032 and my fuel trims are -1.3 (short) and 0 (long).
    From my understanding of the sticky on checking for vac leaks these are acceptable.
    It does however suggest I am running rich on idle. What would cause this?
  1. misfire
    By renton in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2011, 20:45
  2. S3 misfire when cold
    By rsstu in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2011, 22:23
  3. Misfire when cold on 1.9TDi
    By connaco in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2009, 23:18
  4. Cold misfire cylinder 3...help needed please?
    By ketteringfluff in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2009, 20:53
  5. 1.8T misfire - can anyone help?
    By MikeA3 in forum Tuning
    Last Post: 28th November 2007, 09:28
Tags for this Thread
