Volks AutosChris Nott
Results 1 to 10 of 10
    Aug 2009
    Costa del Cardiff
    535
    Fitting new clocks from another S3
    My LCD is almost unreadable, if I bought a new set of clocks from another S3, would there be an issues in using them? Such as the immobiliser or anything else?
    Jul 2011
    Berkshire, Surry, Hampshire tri-intersect
    351
    as far as i know clocks are codded to the ECU and keys... I believe it is possible to recode with vag com but aint no expert my self
    anyway, i'm pretty sure there's a company that fixes the LCD displays. Anyone else help out on this one?
    sideways steve's Avatar
    Dec 2011
    Paisley, Scotland
    344
    The only way you can do this is if you know the PIN code for both your original clocks and the new clocks. If you do not have the pin code for either then you will need VAGDash to pull the pin codes. VagTacho will NOT work on the S3.
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    You can buy a replacement LCD off of eBay, it's about £35.
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    Quote Originally Posted by sideways steve View Post
    ...VagTacho will NOT work on the S3.
    It depends what reg is your car.
    As lads said before if you know immo pin then you would be able to use new clocks. Otherwise you won't start your engine.
    Currently not in the country
    Dec 2011
    Paisley, Scotland
    344
    If its a facelift S3 Vagtacho is useless. I have tried on a 2001, 2002 and 2003 I think it might work on a 2000 model or older though.
    Quote Originally Posted by Danio View Post
    Aug 2009
    Costa del Cardiff
    535
    Mines a pre-facelift, registered in May 00'.
    Is VAGDash like vagcom, just a different program? The clocks in consideration are also off a pre-facelift of the same year.
    No idea on my orginal clocks pin or the new ones. I don't want to pay for something that is useless to me tho =/
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    Yours pre-facelift but it works on can so vagtacho may be useless. If your clock have analog clock then is pre but I think you have digital one already. So vag commander do the job.
    Aug 2009
    Costa del Cardiff
    535
    Yea, my clocks are digital, with no analouge clocks, so if the clocks are also digital out of the pre-facelift I could technically get hold of the clockpins of each and simply replace the clocks?
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    You still need to get immo pin of the new clocks otherwise it won't work. And you need vag commander to get it out.
  1. Replies: 0
    Last Post: 20th December 2011, 20:48
  2. Clocks
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2011, 00:29
  3. A3 clocks
    By Crashlanding in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2009, 19:03
  4. A3 and S3 clocks are they the same?
    By garyrmills in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2009, 12:10
  5. Fitting a new set of clocks - how easy is it.
    By Tim20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2008, 16:27
