Volks AutosEM Tuning
Results 1 to 23 of 23
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    Power Loss issues (VCDS Error inside)
    Hey guys,
    I have an ongoing issue with my lambda sensor which meant my EML was on, but im getting that sorted by replacing the sensor soon, however, I noticed that the car was feeling like it was misfiring a little when under load, so I did a scan on the car and it came up with a different error code this time.
    16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    I have been on Ross Tech Wiki and it shows the below, but im not too sure on what it means.:
    Possible Symptoms
    Power Loss
    Possible Causes
    Camshaft Adjustment Valve 1 (N205) faulty
    Fuel Pump Relay (J17) faulty
    Mechanical Timing not correct, including Chain and/or Belt timing.
    Possible Solutions
    Check Camshaft Adjustment Valve 1 (N205)
    Check Fuel Pump Relay (J17)
    Check Mechanical Timing
    Can anyone advise on what the issue could be and if this is what is causing the missing issue
    Thanks in advance
    Nilz
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If not had a new belt lately i would whip the rocker cover off and see if the chain tensioner is ok maybe?
    Nilz's Avatar
    Apr 2006
    10,096
    Belt was done about 20k ago Dave.
    With the chain tensioner, what am i looking for?
    Also whats the N205, as I cant find much info on this at all!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The chain runs on small plates, maybe they are worn causing the chain to run slack..? like my AGU head was....
    RIP S3dave
    May 2004
    nr Glos
    7,196
    lee's did this.. it was his vvt tensioner malfunctioning
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Nilz's Avatar
    Apr 2006
    10,096
    OK for some strange reason after doing a scan last night, the lambda sensor fault has now disappeared, i have had it for months and the EML light has gone off as well since clearing it.
    Previously when clearing it, it literally came back straight away all the time, but last night it didnt and after a long drive this morning the EML has still stayed off.
    The car does still feel like its missing a bit though on load when flooring it and feels 'heavy' as if its struggling to put the power down, although it does put the power down.....im hoping this maybe related to the sticky handbrake issue and once the springs are fitted, they may release the brakes fully which will not make the car feel as heavy - does that sound right?
    I will do another scan again tonight and see if the above error code comes back and will report back.
    Thanks for the responses so far guys
    Nilz
    Nilz's Avatar
    Apr 2006
    10,096
    OK so I spoke too soon, just went out at lunchtime to get the springs for my brakes and the EML has come back on.
    A scan later will reveal all
    Aug 2010
    1,540
    sounds like the vvt is acting up.
    the vvt is fed oil pressure thru a passageway in the head, the solenoid directs the oil pressure to one side of the chain or the other, to effectivly lengthen or shorten one side of the chain or the other, to advance or retard the inlet cam.
    the ecu keeps an eye on how effective this is via the inlet cam position sensor on the cambelt end of the head.
    this fault means the ecu isnt seeing the range of advance/retard it should do in given operating conditions.
    its not a belt timing issue........ if you get the belt out even a tooth and start it, it does run but wont rev above about 3000revs and within seconds the engine light comes on and you get a "cam/crank incorrect assignment" or similar fault. i know this!
    Nilz's Avatar
    Apr 2006
    10,096
    Right I have just been out and scanned the car as the EML came back on again and luckily the above error has not come back, the only one that I have at the mo is the one about the lambda sensor, which I have got today, so will hopefully replace in the next few days.
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Good luck nilz, hope its just the lambda. thought i saw you the other day at a shell but that s3 had a fmic.
    Nilz's Avatar
    Apr 2006
    10,096
    Nice one dude,ive sent you a pm.....i know that other s3,ive seen it around the area a fair bit as well.
    Feb 2008
    2,817
    Hope you get this sorted nilz.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Nilz's Avatar
    Apr 2006
    10,096
    Same here Rav, just want my baby back LOL
    Aug 2010
    1,540
    what lambda fault code have you got? if its just a heater open circ fault then thats not causing the running fault.
    Nilz's Avatar
    Apr 2006
    10,096
    Nilz's Avatar
    Apr 2006
    10,096
    Another update, I put the springs on last night, handbrake didnt stick this morning, but it wasnt too cold either, so not sure if it has done the trick.
    Still getting the heavy feel, but im yet to change the Lambda, which should hopefully get done tomorrow.
    Nilz's Avatar
    Apr 2006
    10,096
    OK I changed the lambda sensor and cleared the fault and its all good so far..
    However, I am still getting a slight misfire, I had a visual check, but couldnt find any leaks or anything and im not getting any more fault codes coming up.
    Any ideas?
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Was that the Lambda we changed a while back Nilz or the other one?
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    134
    Quote Originally Posted by Nilz View Post
    Any ideas?
    Give the crank sensor a clean if that dont cure it borrow one from someone elses engine to trial and error test.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by R-Tech-Nick View Post
    Bloody hell i wouldnt want to be taking them off and on willy nilly there a right pain to get at...for us amateur mechanics of course Nick..
    Nilz's Avatar
    Apr 2006
    10,096
    Steve, it was the other one, the one attached to the cat, we changed the one in the engine bay.
    Thanks for that Nick, crank sensor - (Dave - where is it?? LOL)
    It actually feels like when the coil pack is on its way, but not as severe....its a bit of a wierd one, but without any codes or a clue to what is causing the prob, im a bit stumped (even more so with my vast - i mean lack of knowledge of mechanics!!)
    Im hoping its not the coils, as it has been in for the recall and had a couple changed as well, they said the others were ok.
    Anymore ideas??
    Oh it also feels like it could be a boost leak, but im not sure how to check any further.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its not really visible but you can feel it near the bottom of the engine at the front, it really is well hidden and a bugger to get out , the best way to find it is to follow the wire from under the manifold and follow it down...
    Nilz's Avatar
    Apr 2006
    10,096
    That sounds like a fun job!!
    Once I have it, what needs to be done, oh and any other ideas of what it could be?
    Would a boost leak show up on a scan with VCDS?
  1. Help from an expert please? maybe NHN Error code inside <3
    By mkimjoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2010, 10:53
  2. Cat Sensor Error Codes from VCDS....
    By jb0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2010, 08:44
  3. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th April 2010, 07:38
  4. Loss of power under load, blue smoke, VCDS codes.
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2010, 17:58
  5. Help / Advice needed, A3 1.8T, Power blipping /slight loss of power
    By Lex007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2009, 09:49
