Chris NottMonster Motorsport
Results 1 to 7 of 7
    Jul 2005
    Kent
    29
    Engine rev-up on starting
    Sometimes I will start my motor and the engine will rev up as if I had my foot on the gas. It only lasts a second or so, but it can be quite alarming.
    Its a PD130 TDI.
    Any idea what is going on?
    Warmonger
    Sep 2004
    Greenhithe, KENT
    342
    Re: Engine rev-up on starting
    is this not the cold start mechanism ??
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Hi,
    got the same engine, mine goes up a little - only to about 1500 revs though and then back to idle speed.
    how high does it rev then?
    Mike
    Jul 2005
    Kent
    29
    [ QUOTE ]
    Hi,
    Mike
    [/ QUOTE ]
    It goes to about 3000. But it is quite intermittant (2-3 times a week) and the outside temp doesn't seem to have any bearing on when it does this.
    Carlos
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    To be honest i'm not sure, sounds very odd indeed!
    Might be worth posting this in the diesel forum as well, they can answer most questions about oil burners
    Mike
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    [ QUOTE ]
    Its a PD130 TDI.
    [/ QUOTE ]
    My Passat Tdi PD does this occasionally, it only seems to happen when the engine is started up when its warmed up. I've had VW do a check up, and they can't find nothing wrong [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    shouldnt think its a problem tbh, could be any manner of things but nothing i can think of that would cause damage.
