Volks AutosChris Nott
Results 1 to 14 of 14
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Headunit advice and help
    Hi everyone I'm getting to my wits end with my Audi Bose headunit, the dreaded volume chip is driving me mad and I have had enough, I just wanted to ask has anyone changed their headunits with non Audi factory o se and had any problems? Is it a simple swap? But I do have the subwoofer and don't really want to lose it so is there a good replacement headunit I can use that still allows me to plug the woofer in and use without any problems? I just want a iPod friendly headunit with sd card reader installed
    Any help would be great and thanks for reading
    Customboy
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    Jun 2003
    World of my own
    9,813
    You need a fascia adapter, pc9-410 harness adapter (providing the new HU has front & rear pre-outs) and an ISO antenna amp adapter. You can get popping from the Bose amp, but this depends on the HU, some do some don't. The subwoofer will still work.
    You'd be better off replacing like for like and buying a Connects2 or xcarlink iPOD adapter IMO
    Alex Turner
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    When I enquired about this the guy in the car audi place said bose systems are a pain in the back side to swap over, you need some adapters for the speakers as they are 2 ohm or something... Just rip the whole bose system out or buy the adapters..
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    Customboy's Avatar
    Jan 2012
    SE London
    836
    p
    Jan 2012
    86
    hello mate rather than buy new headunit and have all the hassle of finding the right wiring loom, send it to this guy Car Audio Technics he is in brentwood in essex and can repair the volume control for £80 he done mine and his work is second to none. you also recieve a warrenty for the work he has performed.
    james
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Oh brilliant Buckley! Cheers buddy will do might also buy the link as well as I do like to connect my iPhone to it but then again my tape adapter does a fine job aswell !
    p
    Jan 2012
    86
    seriously i bought a new headunit sony ipod unit, it worked with everything like the sub and that but the quality of the sound it just not the same, the standard bose system will not be beaten unless u spend alot of money.
    James
    Jan 2012
    86
    just realised your only in london so brentwood not to far from you anyways.
    james
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Yeah will ring them on Tuesday and see if I can just pop down there and give it go them, is it easy to remove the headunit does it cause any problems?
    p
    Jan 2012
    86
    nope you just need the relase keys from halfords £3 and it pops out and theres a couple of plugs behind it and an arial.
    james
    Jan 2012
    74
    Swapping out the BOSE for an aftermarket is pretty easy, I Have just done it and swapped out for the JVC KD-R521 with the BTA100 Bluetooth handsfree kit, The Head Unit looks pretty cool as it is mostly lit in red so matches existing styling. You will need the Loom adapter, a crimping tool, some connectors, 2 x ground loop isolators and some insulating tape
    1998 Audi A3 1.6 Sport
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Quote Originally Posted by BtownA3 View Post
    What's the sound quality like? And do you get the 'popping noise'
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Jan 2012
    74
    sound quality matches the bose in my opinion and no popping thanks to 2 ground loop isolators - the bluetooth kit is pretty awesome have no complaints from people i call they often dont realise im driving
    Jan 2012
    86
    mine all worked ok, the sub was active and the speakers sounded ok but i still found better quality out of my bose stereo, other thing that was noted with the sony headunit that was put in, it would interfeare with the vag com gear so they were unable to code read and look at it on the comptuer as it kept coming up with connection fault, but as soon as u unplug the headunit it was able to connect.
    james
  1. Got HEADUNIT removal keys... But can't remove Headunit???
    By kevin00 in forum In-Car Entertainment
    Last Post: 14th May 2011, 09:53
  2. Advice on Headunit Wiring (Manually) - HU to keep memory
    By Brooksy in forum In-Car Entertainment
    Last Post: 29th September 2010, 13:34
  3. Help With new headunit ?????
    By Mike071288 in forum In-Car Entertainment
    Last Post: 17th May 2009, 10:42
  4. New headunit advice
    By stevey_boy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th February 2009, 23:29
  5. Advice regarding Chrous -> higher spec headunit
    By Drysdale in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 14:49
