Sky InsuranceVolks Autos
Results 1 to 12 of 12
    Feb 2011
    Plymouth
    939
    Forge TIP fitted... And..
    So we fitted the forge pipe today that I got from DPM, cheers Damion, and I noticed the forge 007p is quieter and flutters like the standard bosch one used to, I was just wondering if this was normal?
    The car feels a bit slower low down but that could be just me, I'll do some logs with Vagcom later to see if there has been any improvement.
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Should be louder if anything mate, did you plum everything up properly?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    And should pull better mate even on a a3. It all fitted right?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,454
    make sure you put the N75 back in the right way round
    Feb 2011
    Plymouth
    939
    Yeah everything is back in properly, had to bodge the small pipe that comes out the top I the 007p, would that be causing it to flutter?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    nope. somethings plumbed wrong. or kinked to the dv or something.
    it should work just he same after the tip was fitted
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Feb 2011
    Plymouth
    939
    So even if the pipe at the top was kinked/restricted it shouldn't flutter? The turbo sounds a lot louder now, the dump is quieter but flutters, but top end of the rev range there is quite an improvement.
    A3 Oly's Avatar
    Dec 2010
    Mansfield, Notts
    235
    the flutter will be ur turbo so it sounds like the dv is not working, prolly because the vacum pipe is kinked or split, when i did my 007p the old vacum pipe was like rigid as fook so replaced the lot.
    A3 1.8T Sport (98)
    Fusion Stage 1 Remap
    Pipercross Panel Filter
    Forge 007p Recirc Valve
    Stainless Exhaust
    G60 Solid Flywheel & VR6 Clutch
    3 Careful Owners
    Feb 2011
    Plymouth
    939
    Done a few logs with vagcom tonight and the Mass air flow reading has dropped which by working out a BHP figure from my logs before the Forge TIP was installed and it shows a 4BHP drop also a fault code has appered in vagcom which is:
    1 Fault Found:
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-00 - -
    Readiness: 0000 0000
    Pretty sure this is because of the bodge job on the top of the 007p so will get new silicone hose for this pipe and see if it stops the DV from fluttering. Had another look at the pipe and everything looks the same as when the standard TIP was on the car.
    Thanks for all the help so far. Hopfully i'll be able to sort this annoying issue out!
    DJ_Troopa's Avatar
    Back in a turbo!
    Oct 2008
    West London
    1,735
    Visit DJ_Troopa's Instagram Channel
    Sort the DV pipe issue out first and then do the N249 bypass.
    Inferi Black Cupra K1
    Feb 2011
    Plymouth
    939
    Right, so, as cockups go I'd say this was quite a good one. Initially when installing the TIP I took it to a garage my mate works at to pick up some bits and was offered to install the TIP using one of their ramps. Great I thought, easier access, loads of tools and a qualified mechanic on hand.
    Installed the TIP perfectly fine until we got to the smaller pipe on the top of the forge 007p which wasn't long enough, so the qualified mechanic came up with the idea of using a connector and a bit more length of pipe. Which by looking at it seemed like it should work fine.
    However I looked at it today and the "connector" didn't actually have a hole through the middle and was effectively acting as a bung. Replaced this whole pipe with a new section of longer pipe, clipped it all in tightly and took it for a drive.
    Seemed to release the air with a whoosh like it used to except its a lot quieter now, I've read that it is quieter with a TIP installed on a non mapped car on ukmkiv's. So I'll do a log with vagcom later on in the week to see if the TIP has had any improvement over the standard TIP.
    However thecar does seem to be a little more powerfull now but that could be because I got used to having a malfunction running on the car it also doesn't hesitate at 4000 rpm like it used to now, so I'm kinda happy, apart from losing some of the childish loud whoosh noise.
    deeman88's Avatar
    Watch this space...
    Aug 2011
    SE London
    418
    glad yu got it sorted out mate and good luck with the N249 bypass
    My Build Thread... Nothing too special
    Mods: ASN Sticker on Rear Driver Window, Forge 006, KO3s Turbo, Silicone TIP, 3inch Downpipe, Decat, FK Coilovers, Bosch Aero Retrofits, NGK 6458 Sparkplugs.
    To do : Front and Rear 25mm ARB, Strut Brace, Adjustable Droplinks, Poly Red DogBone, Remap, FMIC... to be completed
  1. Fitted Forge TIP today......
    By slowcoach3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2011, 09:24
  2. FORGE TIP
    By Danny Cawsey in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2010, 12:17
  3. A3 Forge TIP help
    By big_mo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2009, 11:55
  4. NEW FORGE TIP FITTED, Soooo GOOD!
    By mrj0ey in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2007, 12:50
  5. Forge TIP
    By Daniel Vzla in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2007, 20:31
