Volks AutosMonster Motorsport
Results 1 to 26 of 26
Thread: Soft Brakes
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Soft Brakes
    OK so I noticed my brakes had gone soft a few weeks ago all of a sudden, so I did a full brake fluid change, bled all the brakes and the master cylinder, whilst doing this, I noticed the rear pads were VERY low, so I changed them as well, but the brakes still feel very soft, so I bled the MC again today, but still no difference, they still feel like they are not quite there (if you know what i mean).
    Does anyone have any thoughts or ideas on why this has happened or how to sort it
    Its a 2002 AMK S3.
    Thanks in advance.
    Nilz
    a3tdi2001's Avatar
    437
    Might sound ridiculous but I had a similar problem after having the back axle off to do the bushes. The brakes came back into their own after a couple of days driving. Maybe some air was trapped somewhere?
    Nilz's Avatar
    Apr 2006
    10,087
    Its been 2 weeks since the fluid change and a week since the pad change too.
    Also, i noticed that my handbrake was sticking a while ago, my drivers side rear pad was totally flat, as I think it was sticking to the disk, the passenger side was fine and there was plenty life left on this side.
    Released the handbrake, WD40d it and that seems to be ok now, still the brakes dont seem to be there tho!!
    Think its worth rebleeding all the brakes and MC again?
    a3tdi2001's Avatar
    437
    Could be worth bleeding them, but I'm no expert to be honest. I read in the Haynes manual for the A3 that they should be done in a certain order but not sure how important that is. Are you using a pressure bleeding kit or getting someone to give you a hand?
    Nilz's Avatar
    Apr 2006
    10,087
    Ive been doing it with my uncle who is a mechanic, im pumping the brakes, while he is bleeding them.
    a3tdi2001's Avatar
    437
    Could there be a problem with a sticking piston on the driver's side rear or does the caliper definitely release after you press the brakes? Just wondering if you might have tested with applying the handbrake and thinking it was releasing fine but it could be sticking when you use the brakes?
    Nilz's Avatar
    Apr 2006
    10,087
    No its releasing fine now, checked all of that and its all ok now.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Try using a pressure bleeder rather than the old-skool pumping the pedal method.
    It could be a faulty master cylinder, or a leak.
    TD5 Land Rover Defender build
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Nilz, let me know if you need to borrow my pressure bleeder, it's so much easier and I manage to do it on myself. Instant brakes back on the S3 I sold to Gops!
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Have you checked the brake booster pipe coming off the inlet mani? My brakes were foobed a while a go and i sorted it with a bit of insulating tape around a crack in that vac pipe
    Audi A3 1.8t AUM
    Forge 007p, Pipercross Panel Filter, Eibach Prokit 35mm drop, EBC Green Stuff Pads
    Groved Disks, HEL Braided Brake Lines with Dot 5.1 fluid.
    Creation Motorsport Silicone TIP,
    N75 hoses, DV Hose & 10mm Rear Wheel Spacers
    Powerflex Rear Beam Bushes & Diesel Dog Bone Bush
    8k HID Kit, 8k LED Side Lights, 8k Number Plate LED
    Jan 2011
    Glasgow
    233
    Soft brakes on my S3 meant Brake master cylinder is the fault. Whole unit has to be replaced. Quite common on Audi 8ls & TTs.
    Nilz's Avatar
    Apr 2006
    10,087
    Jo, will need to give you a shout if you are free to give me a hand with this, I need to check the pipe as well....is it the one on the left hand side, if you are looking into the engine bay, im pretty sure i replaced all of that recently, so hopefully not that.
    Noticed my handbrake has started sticking again yesterday!!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Quote Originally Posted by Nilz View Post
    Not had much time to work on my own car! lol
    Lets try Thursday night?
    Feb 2008
    Manchester
    158
    I have exactly the same problem rear o/s on my a3 1.8t. i have changed discs/pads and eazi bled all lines in the correct order and still the same! i have also replaced the vac pipe going into the brake servo(as it was split). i have ran out of options! was just about to live with it when i came across this thread.
    i hope someone susses it out, please please let me know.
    Tom
    Nilz's Avatar
    Apr 2006
    10,087
    Cool Jo, will give you a shout in the day, as im off then anyway.
    Tom, we will let you know what happens.
    Have you bled your master cylinder, as you havent mentioned that above??
    Feb 2008
    Manchester
    158
    Cheers Nilz, i bled the 2 nipple underneath the reservoir (i think its the slave cylinder). does the master cylinder have a bleeding point?
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    The master cylinder sits under the fluid bottle and that has two nipples. Tried cycling the abs pump using VCDS?
    Audi A3 1.8t AUM
    Feb 2008
    Manchester
    158
    sorry dude, I'm getting master and slave mixed up! I bled the 2 nipple under the brake fluid reservoir(they are a nightmare to bleed without getting fluid everywhere). looks like i'll have to wait to see what nilz finds.....
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Seriously through, if your having problems and have tried everything apartment from cycling the MC, I'd get it done..
    Audi A3 1.8t AUM
    Nilz's Avatar
    Apr 2006
    10,087
    The master cylinder is the one in the engine bay, top left hand corner next to the brake fluid bottle.
    To be honest, my brakes feel like they are back as they were now for some reason, however my handbrake is still sticking, so am going to get my springs tomorrow and see if I can get them fitted this week - see the other thread about that.
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    Good to hear your back up and working.
    Audi A3 1.8t AUM
    Nilz's Avatar
    Apr 2006
    10,087
    I needed my brakes earlier when some tw@ pulled out from behind a tractor to overtake it and came head on towards me without checking if it was clear or not, luckily he got back into his space, otherwise, I would most probably not be here typing this right now!!!
    Metro's Avatar
    Error
    Nov 2011
    Derbyshire
    384
    That's the time when you need a front mounted RPG cannon... Why won't someone do a built thread on armouring an s3 8D
    Do I need to get out more?
    Audi A3 1.8t AUM
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Maybe you activated the ABS during your emergency stop, this sometimes brings the brakes back!
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Another vote for a tired MC
    Nilz's Avatar
    Apr 2006
    10,087
    Well im hoping as Jo has suggested that maybe the ABS has sorted them, but will see how it goes and update accordingly.
  1. Am I going soft.
    By damo.h in forum General Chat
    Last Post: 20th June 2011, 12:09
  2. Soft I.C pipes
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2010, 21:15
  3. soft limp??
    By malcolm30029085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2010, 22:39
  4. Windscreen 'too soft'
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2008, 16:16
  5. soft pedal
    By harper4984 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2007, 13:12
