Sky InsuranceBadger5
Results 1 to 13 of 13
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    Exclamation Could This Be My Boost Leak ?
    I've been thinking i could have a boost leak for a while now and today i noticed the jubilee clip has cut into this hose (marked in red):
    Could this be a boost leak or does the one way valve stop that?
    Also can i just replace it with some silicone vac hose?
    Audi A3 T sport (8l) AUM 2001..... Stage 1 Remap , Bailey DV30 , HID Headlights , LED Sidelights/Footwells , Catch Can , N249 Bypass , Tinted Windows .....
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    will cause a boost leak.
    replace as its the vacuum pipe for your brake servo
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    Quote Originally Posted by jay1601 View Post
    I thought so....lol I wasn't sure with it being for the brakes that it could cause a boost leak.
    Can i just use some silicone vac hose?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    Jan 2009
    West London
    269
    Use some brake servo hose so that it won't collapse and cause your brakes to fail. Just search on ebay or alike for 'brake servo hose' and find the correct size. Can you not just cut the damaged part of the existing hose off and then fit it back on if there is enough length on it?
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    Quote Originally Posted by Andy123 View Post
    Good thinking batman, ill give that a go
    The reason i wanted to change the hose is because i was going to change all of the hose so i wouldn't need to keep that bolt in there as a plug....lol
    Do you know what size hose ill need?
    Jan 2009
    West London
    269
    Not sure mate- just measure the id of the original hose. I'd just cut the original damaged part off and join it back up if you can, saves time and money.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    I'm going to give that a go mate but i would still like to get rid of that Y hose to neaten things up
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    I tried cutting the hose down today but the plastic tube from the one way valve stopped me from being able to put the hose back on
    So i found a bit of hose i had laying around ad it was a perfect fit:
    The hose i had is on the right....lol
    Do you think this will be ok as the original hose doesn't even look like servo hose.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,316
    OVer a very short length it'll be fine. It's over longer lengths where you need to use proper vacuum tubing as normal hoses can collapse under vacuum
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Is there a picture of the hoses you need to ckeck....i've gotta do mine at some point cos i refuse to believe that whistling is the carbonio
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    your soon find out if it doesn't hold.
    as when i has my car mapped it caused the pipe to pop of the manifold (one your having problems with) as it popped the old clips off. which caused the brake pedal to go hard (due to no vacuum) and stalled the engine.
    A3 T's Avatar
    Lord Of The Rings
    Feb 2011
    1,007
    Thanks guys
    I couldn't find anywhere that sells 13mm servo hose so I've had to order it online.
    This one should hold out until it shows up (i hope).
  1. Boost leak, Weak Actuator or boost gauge?
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2011, 13:51
  2. boost leak maybe ?
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2010, 13:13
  3. BOOST LEAK!
    By grays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2007, 18:20
  4. Boost Leak
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2005, 15:17
  5. Boost Leak
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2004, 20:47
