Volks AutosChris Nott
    ANDYMC_TQS's Avatar
    FIRE UP THE QUATTRO
    Mar 2011
    COLCHESTER
    43
    haldex intermitant problem, hopefully just in need of oil change
    hi guys got a bit of a problem with the old haldex and hoping its just because its long overdue an oil change.
    everything was ok with it until a couple of days after we had the snow (which was alot of fun ), i left my house as usual but once i got past 10mph the back end started to wobble around like it was dancing. i did a lot of reading on here and determined it could be my pre-charge pump or worst case the haldex clutch which all said it would be easier just to get a second hand diff.
    the strange thing i was finding was that after about 10 mins of driving it felt fine again and now since the weather has improved it rarely does it unless its very cold outside.
    so my question is really..... could i be lucky enough just to need a oil and filter change
    is it a common thing i have overlooked
    many thanks
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    I'd start with a haldex service and see how it goes
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    ANDYMC_TQS's Avatar
    FIRE UP THE QUATTRO
    Mar 2011
    COLCHESTER
    43
    special tool here i come then!
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Not unless you no someone with one, or anyone on here that lives near by with one. Borrow for a day.
    Cheaper
    Dec 2013
    Quote Originally Posted by ANDYMC_TQS View Post
    many thanks
    Hi did you find a cure for the problem. My car has recently started doing this!! However I have done my haldex services over frequently and had my rear diff oil changed 10k ago.
    i did notice it when warm at Santa pod last year a little but only done it reveny with this cold weather.
    please let me know thanks Ben.
  1. haldex oil change
    By jessie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th January 2012, 12:27
  2. Haldex oil change?
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2012, 23:06
  3. Haldex Oil Change
    By treefrog73 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2011, 14:17
  4. Haldex oil change
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2009, 23:30
