EM TuningSky Insurance
Results 1 to 27 of 27
    Feb 2011
    109
    Looking To disable ESP
    I want to remove the esp completely from my 2000 S3, I'm pretty sure I know the codes but not sure what ABS unit I have, the mk20 or MK60 anyone know able to help.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by S3 Sly View Post
    Surely just pushing the button to turn it off would be the easiest solution
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,275
    How do you intend to do this? I looked into it a while back and couldn't find any solution.
    I wanted to revert the way the ESP button worked so that it was off when the engine was turned on and you had to physically hit the button to turn ESP on. (which will be never )
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    Early s3's had esp enabled and no switch, so i assume the OP wants to try changing the softcode so it doesn't know it has ESP
    Feb 2011
    109
    I'm pretty sure even when you switch off it's not off 100%. Plus I like to play around with things
    Feb 2011
    109
    Yep that's pretty much it, I'm off outside now to have a play. If I succeed Westy I'll let you know.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,575
    When its switched off it is actually off... its not that intelligent tbh...
    <tuffty/>
    Sep 2010
    Devon
    756
    Quote Originally Posted by Byzan Photography View Post
    Does this mean that all early s3's had esp, the only difference being some had a switch to turn it on/off?
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    Westy's Avatar
    Dec 2008
    17,275
    Quote Originally Posted by slowcoach3 View Post
    I'm sure Mark's (Byzan) comment isn't right! I thought original S3s didn't have ESP (hence no button) and it was added to the later models as an extra safety device for your average driver.
    There's no way mine would even be drivable if I couldn't turn it off. If I forget to turn mine off I soon know about it!
    S3 Build Thread
    Feb 2011
    109
    I have an esp fault somewhere which after swapping several things I still can't fix, when it's enabled the car just bogs down/dies as soon as I pull off.
    Anyway I have managed to disable it in VAGCOM. I took the software code number 18448 and subtracted 2048 this gave me 16400, 16400 is the new code. (for mine anyway)
    This disables ESP but leaves ABS working. Not had chance to test drive yet as car is on axle stands ready for diff swap out
    Westy's Avatar
    Dec 2008
    17,275
    I have an esp fault somewhere which after swapping several things I still can't fix, when it enabled the car just bogs down/dies as soon as I pull off.
    Anyway I have managed to disable it in VAGCOM. I took the software code number 18448 and subtracted 2048 this gave me 16400.
    This disables ESP but leaves ABS working. Not had chance to test drive yet as car is on axle stands reading for diff swap out
    Interesting stuff.
    What module was this in VCDS?
    S3 Build Thread
    Feb 2011
    109
    I can't take credit for it westy, I was up till midnight and again all this morning looking for the answers.
    Post 3 and post 26
    Permanently and completely disable ESP/ASR on MkIV R32 for track use?
    Westy's Avatar
    Dec 2008
    17,275
    Post 3 and post 26
    Cheers. You should have kept that quiet
    S3 Build Thread
    Feb 2011
    109
    Slipped up there, I could have made out I was a Audi guru
    Westy's Avatar
    Dec 2008
    17,275
    I've just seen the dates on that thread. This is all new info to me, great stuff.
    S3 Build Thread
    Feb 2011
    109
    One of the advantages of working on the NHS IT project, I get lots of google time paid for
    Westy's Avatar
    Dec 2008
    17,275
    Does it show you a list of options in VCDS when you hover the mouse over the code? It normally tells you the numbers for enabling/disabling things. Cant wait to try this out now.
    S3 Build Thread
    Feb 2011
    109
    To be honest I never noticed, I only bought the software the other week and not really had time to play with it yet.
    Westy's Avatar
    Dec 2008
    17,275
    Ok. I've got full VCDS so I'll have a look at this later if I get time and take some screen shots.
    S3 Build Thread
    Nov 2011
    Sturminster Newton
    190
    SLY was that your S3 I saw round yeovil on monday with the dog cage in the back
    A3 1.8TQS Minge blue
    Mods: AP coilovers, Strut Brace, Merc wheels, S3 brakes, hopefully going BT soon
    Feb 2011
    109
    Cheers, I only have the light versn. I'm doing the dog bone bush now so the clean stuff will have to wait. I do like the computer controlled brake bleed option though Coming from a 93 Impreza RA th Audi does seem rather over complicated.
    Feb 2011
    109
    Quote Originally Posted by Grazam View Post
    Na mate, I'm in North Yorks near Skipton, though I do have a dog cage in the back for the pug and staff. The wife wanted a pug, I wanted a new plasma, you can guess who won
    Nov 2011
    Sturminster Newton
    190
    huh im pretty certain I saw a minge blue S3 with personalised number plate S3 Sly might have been mistaken tho it was a pre facelift, sorry for confusion shame about plasma would have been nice
    Feb 2011
    109
    I decided on that username as my mate had S3 Sly and I had T5 OLF and he was going to swap as he had a Golf. In the end it never happened and I sold my plate and he sold his I think.
    Women never understand the need for a bigger TV, just like they don't understand the need for a 7.1 surround and most bloke things.
    Nov 2011
    Sturminster Newton
    190
    haha or the need for a faster car everyday
    Feb 2011
    109
    Westy did you have any joy disabling ESP ?
    Anyone got a pic of the there dash without the ESP button, I'm looking to remove the button now I have got rid of the ESP but not sure what should be there on the early S3.
  28. #27
    Westy's Avatar
    Dec 2008
    17,275
    No mate not had time yet. I'm off on a stag do this weekend too so wont get a chance till next week.
    S3 Build Thread
  1. ESP warning on start up and esp light on dash all the time!
    By Ripitup in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th September 2012, 16:56
  2. Can you disable the alarm
    By Vertigo1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2011, 10:22
  3. disable the immobiliser
    By ALPINE in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd July 2008, 12:23
  4. I want to disable ESP, EDS and ASR!! (S3 8P)
    By Stockholm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2007, 21:51
  5. How to disable EDL?
    By technics100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2004, 11:46
