Sky InsuranceVolks Autos
Results 1 to 14 of 14
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Question Brakes causing vacuum/boost issues.........
    Right.
    Pulled up from work today, parked the car up the drive and let it idle for a minute or 2, but for some reason i pressed the brake to which i noticed the boost gauge move.
    The car idles bang on 20 inhg without any movement on idle now but, when i started to press the brakes, the vacuum was creeping up to 17/18 inhg, if i kept pressing the brake the needle would just keep flicking up and down between 20 and 17 inhg.
    Now to me this isn't normal and shouldn't happen, it should sit bang on 20 inhg regardless of the brakes!
    I do remember Andrew having to replace the brake pipe behind the heat shielding next to the bulk head, cant remember what the proper name for it is, could this be at fault?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    its normal. the brake booster runs off the vacuum system (normally pipe coming off the intake manfiold)
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So does yours do this jay?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    mine will go between 18-21depending on throttle load, gear, braking, ect.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What on idle? Surely if the cars sat idling then the idle shouldn't move.
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,247
    when on idle (no brakes or clutch/gears) will sit bang on 20
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    yeah thats what i mean mate. I was sat on the drive earlier in neutral and then the above as post 1# started happening which to me doesnt seem right.
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Mine never sits bang on 20? Always about 16inhg. What would this indicate. Also it fluctuates when steering wheel is moved, even at idle :s
    MODS - Custom Code phase 1, 007p DV, various powerflex bushes, EBC grooved and drilled - red stuff pads, N249 deletion. Badger5 V2 80mm TIP. Scorpion backbox + custom centre section, LCR front splitter, Jetex Fr-08001, R32 rear ARB, Forged IE rifle drilled rods, 20mm rear & 15mm front spacers.
    TO DO - Coilovers, adjustable tie arms, DP/mani/decat, FMIC and new remap
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    MAY JUST BE YOUR GAUGE MATE, BUT YOU WANT IT TO SIT AROUND 18 TO 20 INHG, IF LOWER THEN NORMALY MEANS A VACUUM LEAK ETC.
    MINE DOESNT DO THAT WITH THE STEERING WHEEL.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So anyone else any thoughts?
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Turn on your heaters
    Open your electirc windows
    Turn on full beams....... it always drops a tad
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Quote Originally Posted by S3featesV9 View Post
    Nothing to worry about mine is exactly the same.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    S3featesV9's Avatar
    Dec 2010
    Oxford
    1,030
    Yeah. All good and bill said it should fluctuate when steering wheel is moved as it putting load on the engine.
    One less thing to worry about
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thanks lads.
  1. Replies: 4
    Last Post: 18th January 2012, 18:50
  2. Brakes - Issues
    By lgooch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th October 2011, 16:00
  3. S3 - Only full boost after vacuum
    By The Stig in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2010, 22:14
  4. No boost and loud vacuum noise
    By quattro rob in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2009, 22:53
  5. 1.8T Sport Boost/vacuum with forge split-r
    By alex-qts in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th April 2009, 18:37
