AH FabricationsEM Tuning
    Feb 2012
    a3 1.6 sport firing on only 2 cylinders
    hi guys, got a 2000 plate sport, the car is firing on 2 cylinders only, i got a new coil pack and tried that,exactly the same.i have clipped an inductive timing light to each of the ht leads and there is nothing coming out of the coil .just wondering if there are any common faults that i should be looking for? i am presuming either a wiring problem or a faulty ecu. no warning lights lit or flashing on the dash to indicate a problem. and ideas appreciated!
    Feb 2012
    just traced all 4 wires back to the ecu plugs and tested with a continuity tester...all check out ok.does this mean an ecu fault ? or could anything else have an influence ,sensors ect?
    BENJAMIN's Avatar
    Mar 2011
    460
    Check your camshaft angle sensor and wiring mate.
  1. Xenon not firing/working
    By s3 Hoggy in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2011, 18:04
  2. 6 Cylinders?
    By Jackal in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2011, 21:35
  3. Cylinder 2 not firing
    By B5NUT in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2010, 18:59
  4. Help.....Lost Power / Firing on 3 cylinders........ ?
    By hop2407 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2006, 22:12
  5. Windscreen Washers not firing?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 08:50
