Chris NottAH Fabrications
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    N249 bypass quick question
    Iv done the pcv simplification and catch tank install which leaves me with a spare vac port on the inlet manifold, can I run a new hose from this to the dv and plug the original hose?
    Just wanted to give it a try before I do the complete removal of the n249
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    beachbuggy's Avatar
    Surrey
    1,727
    Yes. Will work fine for you
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Cheers fella
    1.8T SPORT AUM
    Progression Thread
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Worked a treat, really impressed with the difference in response,
    1.8T SPORT AUM
    Progression Thread
    S3 Paul's Avatar
    Oct 2006
    2,759
    Ive done the N249 bypass but seem to get a fault code from time to time.
    Car drives fine, Its just the random "n249 malfunction" that bothers me.
    Noggy Blue 2001 S3
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Ill keep an eye out for that 1, I have had it before I did any changes to the car, just reset it n it went away
    1.8T SPORT AUM
    Progression Thread
  1. S3 post remap N249 bypass . ! . ? . ! and fuel pressure reg question
    By VAG-Slag in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2011, 18:34
  2. N249 BYPASS YES OR NO???
    By paulsaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2011, 14:21
  3. N249 Bypass???
    By nixy in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2011, 11:55
  4. n249 bypass
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2011, 11:28
  5. N249 bypass
    By cawsey20 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th May 2010, 22:47
