Ive had this problem for a while now and have just ignored it but i think its time to get something done about it! I had some coilovers fitted a few months ago and immediatly after, some odd things began happening..
When i set off, there is a very odd noise i cant really diagnose myself. I'm guessing its coming from the brakes because the brake peddle springs up when you try to press it, it doesnt sound like a grinding or any usual mechanical noise you would hear. its like a tinging or a vibrating sound. Possibly ABS??? This only happens when i set off from a stop up to about 7mph, it goes off when you quickly tap the brake a couple of times or when you speed up, there is no effect when using the brakes at speed, the brakes still work perfectly its just a bit wierd. VagCom shows front right ABS wheel speed sensor, but that has been coming up on the VagCom before i had the coilovers fitted. I tried replacing this sensor but the fault code still shows (comes back on straight after cleared)
Any help or answers would be great!
