S3 Door Blade Fitting
Diesel Quattro
Cheshire, UK
Hi guys, hopefully get a progress thread started tommorrow.
i am looking at putting s3 door blades on my a3 tdi quattro 8L
the ones i am looking at are 2nd hand, do i need anything to put them on? are they just poppers like 205/309s kinda thing??
also, what kind of price are they new and 2nd hand?
your help would be much appreciated
aaron
The door blades are held on with lugs witch are attached to the outer door skin, basically line up and slide into position then secured with a couple of screws from the inside via the back through two small holes. ( how these lugs are mounted I'm unsure maybe screwed or riveted ) the rear blades iv never removed but at a guess will be held in place with something like the fronts.
Unsure what you'll expect to pay but someone on here will know no doubt.
Well I damaged my rear blade on my A4 in an underground car park and Audi only wanted £130 for a replacement (unpainted). Needless to say I repaired the item with some scrim tape, araldite, a bit of filler and a respray, good as new.
