JMB RetrofitsVolks Autos
Results 1 to 25 of 25
Thread: Dipstick tube
    A3AH's Avatar
    Dec 2011
    365
    Dipstick tube
    I believe I may have just broke the dipstick tube.
    Heard a crunch yesterday night after fitting the TIP but. Just checked my oil and now I cant get the dipstick back in and its got tiny bits of broken plastic at the bottom.
    How dangerous is this? Gonna ring tps or audi tomorrow and get another hopefully.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Someone's gonna go fishing
    Something tells me the housing to these screw on....anf off incase anything gets stuck.../
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    S3Zek's Avatar
    Sep 2011
    407
    im quite sure there just push fit and held by a bracket at the top, it was for my s3 anyway. take it off and get the part number, there not much from audi
    Darren4's Avatar
    Feb 2009
    Surrey
    186
    They just twist and pull out. Mine broke when I tried to remove mine, had to keep breaking it to get it off. It cost around £3.70 from tps I think
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    I know it sounds silly but I would take it right out from the base of the plastic have a look down the tube and if you can see any plastic get a Hoover on it! I had to do this when changing my thermostat, One little peice broke off at the bottom of my dipstick tube. I already had a spare tube that I bought from euro car parts for £3!!! so wasn't a big deal.
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    A3AH's Avatar
    Dec 2011
    365
    Thats why it was disconnected because i was gonna attempt the thermostat, but i broke it without even taking it off.
    Atleast i know there easy to fit and cheap to buy..
    How easy is it to remove it to the bottom and hoover out the bits of plastic?
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    This happend to me. I ending up taking the sump off and changing the oil for piece of mind. In theory though,the oil pick up has a mesh shield so the plastic should get sucked into the engine
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    A3AH's Avatar
    Dec 2011
    365
    Quote Originally Posted by Paradox1 View Post
    In theory it should get sucked in or shouldnt
    beachbuggy's Avatar
    Surrey
    1,744
    06A 103 663 B
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by A3AH View Post
    In theroy, it SHOULD NOT do into engine as the mesh acts as a fiilter for inpurities in the oil
    A3AH's Avatar
    Dec 2011
    365
    Cheers guys.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Put the new one in boiling water for 10 mins or so before you attempt to fit it, otherwise you may well end up snapping it as you try to fit it.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    A3AH's Avatar
    Dec 2011
    365
    Thanks for the heads up, cant be bothered with any more speedbumps.
    Aug 2010
    1,540
    the old one on your car will have gone brittle with age and heat. new ones are quite sturdy and flexible to a point. doubt you break it fitting it unless your heavy handed or/and use a lump hammer to seat it.
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Dip stick tube, less than £10,
    Oil pick up pipe, less than £10
    Engine rebuild due to clogged pick up ££££££££££
    If you haven't replaced the pick up pipe and your car is of higher miles I'd be tempted to do it soon, it will cost less than £100 for all the genuine Audi parts and castrol oil and filter
    I replaced my dipstick tube when doing the pick up pipe,
    Imola yellow S3 APY.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by bazil:1504789
    X2
    Yeah do the oil pick up if its high mileage. I did mine around 85k
    Word!!!
    Oct 2011
    760
    hi
    i did this, and the plastic bits fell in to the sump opps.
    TPS for dipstick tube £2.
    If you do take the sump off, the bolts on the sump are 10mm heads.
    found this out when when undoing the bolts with the allen key head and thought id rounded the head off, looked up and saw they were 10mm heads.
    this was a s3 sump though
    A3AH's Avatar
    Dec 2011
    365
    Im an a3 on 57,000
    Ill get the pick up pipe done, but ive only ordered the dipstick tube atm because I wasnt aware.
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    i replaced my pickup pipe last week at 73,500 miles and it was still fine but its done for peace of mind
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Done mine at 90,000 miles, my car has FASH, I was shocked
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    Had the same broken dipstick tube on mine, only found out when I dropped the oil and found loads of little orange bits in the oil
    Turns out the original owner had bodged the tube back together with a metal sleeve around the outside
    NOB
    Took the sump off for a clean and did a few quick oil n filter changes just for piece of mind
    Now the crankcase breather pipe is starting to disintegrate time to repeat
    1.8T SPORT AUM
    18" TTRS wheels, de-badged grill, tints, TIP, forge 007P, toyo sports oil catch can,
    3" downpipe + decat, Toyosports FMIC, 10mm lowering cups, N249 bypass
    S3 Front Brake Setup, R-Tech stage 1.5 custom remap 218BHP@229FT/LB
    Progression Thread
    http://www.audi-sport.net/vb/a3-s3-f...8t-thread.html
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    How tricky is it to remove the sump, change the pickup and refit the sump?
    How long/much would it take a garage to do?
    I have ramps or can put on axle stands?
    Liam
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    the job itself is not to hard at all, theres quite a few bolts to undo
    my sump was a pain to get off once the bolts were out due to the sealant that was used around the sealing edge,
    have not changed the pickup yet
    took me about 1 hour all in to do, in the garden, on ramps
    1.8T SPORT AUM
    Progression Thread
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Markeyboy, thanks for that.
    Don't suppose you know the VAG part numbers for the sealant? I know I could probably use something off the shelf from Halfords or other motor factor but I like the nice warm fuzzy feeling of knowing, absolutely, that everything has been done the way Audi intended.
    I have the OEM sealant for the rocker cover gasket, which is on my to do list, but I guess that's different?
    Liam
    Markeyboy's Avatar
    Fan of the R-Tech!
    Aug 2011
    Thurrock, Essex
    281
    i cant help with an audi part number, but i got this from GSF
    worked a treat
    1.8T SPORT AUM
    Progression Thread
  1. Dipstick tube
    By Bignick in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2013, 21:07
  2. Broken Dipstick Tube
    By stacey bear in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2011, 15:57
  3. Dipstick Tube
    By Sam_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2011, 23:18
  4. A3 dipstick tube
    By Shug1874 in forum Parts Requests
    Last Post: 26th April 2010, 10:51
  5. Dipstick tube
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2008, 15:36
