EM TuningChris Nott
    Jan 2012
    Australia
    47
    S3 - coilpack issue or something else? Thoughts...
    Hi guys, just wanna say great forum by the way - so much info on here!
    Got a small issue with my 02' s3 - whenever it has a cold start, it coughs and splutters for a few seconds, then idles fine.
    All starts after that are fine, but I noticed under hard acceleration with wide open throttle, it has a very small miss that is like a soft
    Rumble, and it only happens sometimes - which led me to the conclusion that it was the haldex slipping (being new to Audi ownership) initially. I decided to change plugs using a NGK pfr7e plug gapped at .028". For 2 months the miss disappeared but now it's back, but the cold start issue was not fixed by changing plugs. Anybody have a similar issue? Or perhaps could share their opinions on what I could try, I'm in a small town with no access to vag-com for the next few months at least.
    The car is modified with APR tune (195kw) and has an upgraded haldex controller. It is always run on 98 v-power.
    Apart from that it is a fantastic little car. If I can fix this it would be tops!
    Thanks in advance,
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    First thing you could do is phone your local Audi as your car may well be able to have 4 new coilpacks fitted due to the recent recall. They will carry out a free health check on your car also and that might show what's wrong. Although Idealy you will want to get your car scanned where abouts are you as there may be a member with vcds close to you
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
  1. COILPACK OR NOT COILPACK
    By ruffcutz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th April 2011, 21:07
  2. coilpack
    By Jay-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2010, 14:00
  3. Possible coilpack issue ?
    By sean_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2009, 13:49
  4. Is this a coilpack issue
    By Nutkin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th August 2009, 12:10
  5. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
