Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Nov 2007
    158
    2002 S3 Rear Springs
    Hi guys found part of a spring on my drive on sunday and found lower part of drivers rear spring broke,
    just looking for a quick step by step on replacing it as i plan to replace tomorow night
    are the standard springs too small for compressors? and is there a chance of drive shaft popping out?
    caliper off?
    advice greatly appricated
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Rear springs can be done without compressers... all you need to do is undo the damper so that the arm can swing... thing to watch out for is the passenger side (assuming yours is a right hand drive) when doing springs to make sure you undo the xenon levelling sensor from the tie bar before doing anything else otherwise you will snap the arm off...
    <tuffty/>
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    which side are you doing mate? as the passenger side has a xenon level sensor on it so you will have to make sure you unclip it! easy job to change spring you only have to unbolt the bottom of the shock then push the suspension arm down then you will be able to remove the spring without any compressors
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    that shows how slow I am at typing.......
    2002 S3 REVO
    Nov 2007
    158
    Cheers Lads, never changed with drive shafts so was a bit worried. i plan to change both but drivers side first will keep and eye out for my headlight levelling cheers, ive actually DIY repaird my leveler as spotted it broken when under the car one day.
    wheres the best place to jack it off on rear? diff/haldex box?? ive a pit and pit jack btw
    love this forum!!
    Sep 2010
    12
    strmseks3 I have a broken rear leveling arm at the moment.
    How did you diy fix it?
    Just glue of some type? Or did you strengthen it somehow.
    Nov 2007
    158
    i glued it mate, then added a small peice of flat bar to try and strengthen it, was gonna order a new one but reckon that woukd just break to! youd be surprised what arldite can hold
    Sep 2010
    12
    I'm going to be getting some arldite on the way home tonight then :-)
  1. 2002 S3 Rear springs & shocks
    By mattyboy199 in forum A3/S/RS Parts
    Last Post: 28th November 2011, 14:26
  2. Broken rear spring - are BAM rear springs same as AMK rear springs?
    By chris-edin in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2011, 23:13
  3. Front suspension springs 2002 S3 Wanted
    By handy andy in forum For Sale/Wanted - Audi Parts
    Last Post: 6th June 2011, 23:22
  4. DIYT fitting rear shocks and springs, 2002 S3
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2010, 23:59
