Badger5Chris Nott
Results 1 to 8 of 8
Thread: Haldex
    G60DAN's Avatar
    Cornwall
    321
    Haldex
    Hello all
    Right I'm getting an error code 65535 from my haldex had a look at the plugs and there fine put a new earth strap on and still get the code. Now what I would like to know is there any coming back from this
    Internal Control Module memory error or do I need a new one.
    Thanks for any help
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    65535 - Ross-Tech Wiki
    What makes you think its the Haldex? most of the info I have seen suggests the ECU and check sum errors?
    What module did you scan? have you got the output of the scan from VCDS to post up?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Controller may be to blame if its coming from the AWD module...
    <tuffty/>
    G60DAN's Avatar
    Cornwall
    321
    It was AWD module that was scanned.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Controller issue then by the sounds...
    <tuffty/>
    G60DAN's Avatar
    Cornwall
    321
    Right got the print out
    Address 22 AWD Labels 02D-900-554.1b1
    Part no: 02D 900 554 B
    Component Heldex LSC ECC. 0006
    1 Fault Found
    65535 Internal Control Module Memory Error
    00-00
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    That fault code is associated with checksum errors... maybe water in the controller or something... you may be able to remove the controller and take it apart to clean it/dry it/resolder joints etc...
    <tuffty/>
    G60DAN's Avatar
    Cornwall
    321
    Thanks Tuffty will have a look at the weekend and pull it apart and see if it's wet in side.
  1. Haldex help
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2013, 23:40
  2. Haldex clutch pack and haldex controller pump out of audi S3 8L
    By S3LOUD in forum For Sale/Wanted - Audi Parts
    Last Post: 15th February 2012, 17:04
  3. Haldex?
    By PA0L0 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2009, 09:54
  4. Haldex?
    By starski4578 in forum TT/TT-S/TT-RS Forum
    Last Post: 21st September 2008, 20:39
  5. S3 Haldex
    By byrnie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2008, 13:55
