EM TuningChris Nott
    Perry's Avatar
    Feb 2012
    Rickmansworth
    50
    Vibration in 4th Gear
    Pretty much as the title says - when in 4th gear (and only 4th gear) the gear stick seems to vibrate quite a bit, is this something I should be conerned about or is it a common occurence?
    1st,2nd,3rd, & 5th are all ok.
    Thanks in advance.
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    Quote Originally Posted by Perry View Post
    Thanks in advance.
    Gearbox bearings. Has a similar issue in a Golf few years back.
    550 cc Injectors / Milltek Exhaust Manifold
    Forge Silicone / Goodridge Hoses / EBC A/R
    G60 SMF / Launch Control Map
    Powerflex Black A/R / H&R Anti-Roll Bars
    Carbon Wrapping / 104Db @5400 RPM
    Perry's Avatar
    Feb 2012
    Rickmansworth
    50
    Quote Originally Posted by Alais DJA View Post
    Being a bit thick - is this a gearbox out job ? Or is it something that you do by removing the gear stick?
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    No it's internals mate. I'd go to a gearbox specialist to confirm it, mine was done by just replacing the 4th gear, dropped gearbox out and replaced. Only for 3rd to go bang 2 weeks later and shatter the box completly.
    If it's shot, get a replacement, not a repair.
    Good luck
    Perry's Avatar
    Feb 2012
    Rickmansworth
    50
    Good luck
    Sounds like it's going to be expensive :-(
    Alais DJA's Avatar
    Feb 2012
    Southampton
    559
    It's gonna be 3 figures
  1. 4th gear what?
    By camscockle20vT in forum Forum Support
    Last Post: 19th April 2012, 21:40
  2. Gear Stick Vibration in 4th
    By jb0o in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2010, 15:12
  3. Wheel spin in 4th gear normal?
    By Chris128 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2009, 17:02
  4. Loss of turbo in 4th gear
    By DJ-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2009, 13:26
  5. Stuck in 4th gear!
    By Gavin Cooper in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2008, 20:43
