Badger5AH Fabrications
    Sep 2010
    Devon
    756
    large port head part numbers?
    I have a recon head in my nearly working S3 and it doesn't have an engine code stamped into it.....I was wondering if anyone knows the part numbers for the AGU/AEB heads? I've had a good ol' search and can't find them anywhere, if anyone knows I'd appreciate it!
    Russ
    Badger 5 tuned 340 bhp / 350 lbft sleeper
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    So you want to know what head you have on your engine as the bit on the head has been machined off? is that right?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Making a few assumptions... if you are looking for a large port head for your engine then searching eBay for AEB/AGU (also look for A4, Golf and Passat heads as well as VAG used them across the range) will net you the best results as thats how they are typically listed...
    If you have a head but don't know the code as its been machined off then don't worry about it... its irrelevant... its either large port or small port... that is the easy bit...
    If you have the larger ports then happy days... if you have the smaller ones then keep looking
    <tuffty/>
    Sep 2010
    Devon
    756
    Thanks tuffty! I'm going to have a look for part numbers tomorrow whilst we're sorting the timing issues, I just wanted a heads up( !! ) on numbers so I can work out what head I've got, I figured I've a one in 10 chance of being lucky and already having a large port. If I don't its on my list but I want the usual b5 tip, dp etc first up til now theres been no point but things are looking up now so the possibilities are only held up by cash! I might harass tps for the numbers....saves taking off the inlet and measureing
  1. Large port head
    By S3Zek in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2012, 22:44
  2. Large port head help
    By v5 tt in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th December 2011, 20:51
  3. Small port vs Large port head
    By Lemon S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2011, 10:31
  4. large port head
    By jim s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2008, 23:31
  5. LARGE PORT HEAD
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 17:46
