Monster MotorsportEM Tuning
    sideways steve's Avatar
    Dec 2011
    Paisley, Scotland
    344
    S3 Instrument Cluster Startup Sequence/Needle Sweep ?
    Just a quick one, does anyone know if its possible to enable the startup test on a 2001 S3 instrument cluster using vag.com like you can on some of the VW cars ? The thing whereby it does a needle sweep when you turn on the ignition is what I am talking about.
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    No m8 not in 8L. You might do only a output test but that's it.
    Currently not in the country
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,564
    As far as I am aware the 8L dash doesn't do it
    You can change the way the dash/needles illuminate... all off, needles only, dials only and both on...
    <tuffty/>
    Dec 2011
    Paisley, Scotland
    344
    Bummer, I just wondered when I found you could do it on the output test. Thought maybe it could be activated for startup
    I just read about the illumination tweaks yesterday, I might have a play with that actually as just now mine are fully lit all the time.
  1. needle sweep?
    By leeroywarner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2011, 13:42
  2. Needle Sweep on S3
    By DaztheGuv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th June 2011, 13:10
  3. S3 Needle Sweep
    By ScottishS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2011, 12:50
  4. Needle Sweep
    By I'mRonBurgundy? in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th July 2010, 15:14
  5. Needle sweep!
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th December 2009, 14:22
