EM TuningMonster Motorsport
Results 1 to 17 of 17
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Front driveshaft removal?
    Hi all, I need to replace an inner cv gaiter, my question is, are there any nasty surprises in this job or do the shafts come out easy?
    2nd question is what gearbox oil is recomended ?
    The car is a 2000 S3 APY
    Any help or info would be great.
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,043
    Shaft how to is in the stickies
    Not sure about gearbox oil as just got mine from audi
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Gearbox oil is 75w90 semi or fully synthetic...
    <tuffty/>
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    thanks guys, the guide is stickies is a real help, ive ordered 4 CV boot kits from audi just over £120 they had the outer ones in stock but had to order in the inner ones.
    i just hope the CV is ok as there is not a lot of grease left in it. i tried local parts stockists but nowhere could get me a RH inner boot, must be an odd one due to the transfer box?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    6 speed boxes have larger joints... not many parts places keep anything that fit... last one I tried was more or less the same price as OEM so just used OEM the next time it went...
    <tuffty/>
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,160
    Does the oil need to be drained and refilled for clutch or CV changes?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Quote Originally Posted by Westy View Post
    For clutch on quattro (not FWD), not for CV changes...
    <tuffty/>
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    No it doesn't. You can drain it, but you don't NEED to. If you pull the drive shaft out, it will loose oil but there is no need to drain it all out, just put something under the side that you're pulling the shaft out of to catch any oil that is lost. Just don't forget to top it up again with fresh oil. (75W90 Semi or Fully Synthetic) The same goes when changing the clutch. No need to drain the oil, but you'll loose some when you pull the shafts out.
    Ben
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Benjiman46 View Post
    Not on the 6 speed boxes it won't... the shaft doesn't come out of the gearbox at all...
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    If you remove the bevel box to remove the gearbox then you will need to drain the oil...
    You could leave the bevel box on to take the box off but its an cock! to change the clutch on a quattro A3/S3 drain gearbox oil, remove bevel box, remove gear box....
    FWD gearboxes do not need to be drained....
    <tuffty/>
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Ahhh I do apologise! I didn't know that! I've never done a quattro box so wouldn't know... On 95% of all other front wheel drive boxes in the world then
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    Dont the inner CV's just unbolt? Leaving a stub flange in the gearbox?
    TD5 Land Rover Defender build
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Yep
    <tuffty/>
    "Stick a V8 in it!"
    14,909
    Yeh, a lot of FWD cars have the whole thing pull out of the gearbox, but most recent vags seem to bolt on.
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    So finally got up the shed today, I had removed the shaft earlier in the week, I managed to remove and seperate the inner CV and was glad to see no scoring or heavy grooves etc, but I'm kinda stumped how to remove the outer CV,
    Is it the same as the inner one where I have to remove the cap and release the bearings in order to remove from the shaft, I had a search but no results on outer cv removal ( searching on the iPhone FTL )
    Here is a few pics of how I got on
    Is this part avalible by itself? Anyone per chance know the part number?
    And the outer CV, I'm wanting to take this apart for inspection due to the marking near the bearings, looks like its had a bit of heat on it
    Any ideas how to free the cv from the shaft?
    Imola yellow S3 APY.
    Aug 2010
    1,540
    theres a compression clip on the inside. basically get the shaft in a vice and hold the joint in your hand a give it one decent hit with the hammer. should come straight off. if it doesnt rotate it in the vice and hit it again.
    bazil's Avatar
    BOOM BOOM
    Mar 2010
    Scotland
    135
    Thanks, just a bit like pulling shafts from a normal FWD box
    I didn't want to try that earlier just incase I got it wrong, or it was not the correct approach
  1. S3 front driveshaft nut size?
    By ian52 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2012, 18:44
  2. Both front shocks/wishbone/driveshaft Audi S3 8p (9000 miles) 2009
    By AARON77 in forum For Sale/Wanted - Audi Parts
    Last Post: 24th October 2011, 16:21
  3. 2.5 tdi quattro front driveshaft!
    By skwiffy333 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th December 2009, 18:02
  4. front driveshaft gator `outside near wheel`
    By dazzatt in forum TT/TT-S/TT-RS Forum
    Last Post: 20th March 2008, 15:18
  5. ABS & driveshaft removal - B5 quattro
    By Griffter in forum Handling
    Last Post: 29th September 2006, 08:23
