Chris NottAH Fabrications
Results 1 to 8 of 8
    Feb 2012
    Pie eating land
    871
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    2000 Sport TDI - Non Starter - Please help before it burns !!!!
    Hi All,
    I have been having some trouble with my 2000 Audi A3 1.9TDI
    (sport).
    Due to a broken leg the car has
    not moved for over 4 months, so changed the battery as my old one was dead.
    Now the thing wont start, well it does for
    about a second then dies, please see faults below;
    No Key symbol on dash
    No mileage
    No service indicator
    Glow plug light flashes
    Petrol Gauge does not move
    Side Light symbol is constantly on / flashing
    I have tried all
    the main earth wires;
    Behind the sub
    Under the battery
    Behind the steering colum
    Behind the clocks
    Left hand side kick panel
    These have all been cleaned, and it did start (including
    everything on the dash coming back on), ran well until a hill then went into
    limp mode.
    Came home tried a few things,
    left it half an hour and the battery was dead, back to the same symtoms as
    above.
    I have not been able to plug vag-com in as i dont know anyone in the area (wigan).
    I am thinking about sending the clocks and ecu off for testing, but this could end up been really pricey !!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,912
    If your DIS/Mileage etc on the dash cluster arent on, then theres a fault with the cluster or it doesnt have any power.
    Given the immo is also inside the cluster, everything points there.
    TD5 Land Rover Defender build
    Feb 2012
    Pie eating land
    871
    Yeh thats what i am thinking, do you know if it is meant to have 3 plugs or two?
    I can only ever remember undoing 2 but there is a port for a third and seen other people have said remove all 3.
    Also do you know anyone close to get them tested?
    Feb 2012
    Pie eating land
    871
    Found out since the other (small plug) is for the standard radio, hopefully got me vagcom working, so will be trying that tonight, anyone know where i can get a cheap set of clocks from ??
    As i have found a guy in Preston that can recode for me!!
    Only £150 including a call out charge aswel
    B6 1.9tdi Quattro Avant Sport,
    Full zenon bulb kit, Plug and Play chip @165bhp, EGR Delete pipe, Chrome Mirrors, Chrome side repeaters, wind deflectors, Front center arm rest, LED number plate bulbs (when they work), Rear tints, De-Badge Rear, 19" BBS LM's,De-Wiper
    Coming soon -35mm Springs, De-cat pipe.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch, Stereo upgrade, Full Stainless with twin exit !
    Chuck it in & pin it out, nothing better than doing it in the dirt !!
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    Adam if you get sorted with that guy from Preston as we spoke then I'll come in Saturday morning to have a look it.
    Currently not in the country
    Feb 2012
    Pie eating land
    871
    Quote Originally Posted by Danio View Post
    Hi Danio,
    As confirmed see you saturday morning, there aint many people around like you, thanks you
    Feb 2012
    Pie eating land
    871
    Well there has been a brake thorugh and its all down to the top member of AS.N Danio.
    Bought another set of clocks (bargin at £35 - Even though they are for a petrol), Danio popped round half an hour later the car is running, what a top bannana !!
    now i just have a new problem, but it is an ovwer boost issue so not that much of an issue, MAf? Egr? or N75?
    Basically the car revs fine untilll you put it under extreme load, ie, high revs going up an hill, car backs off like it has lost boost or turbo, very random !!
    Will post a new thread all about this though !!!
    Thanks again to Danio there aint many people out there like him, top bloke
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    Any Time m8 got my number in case.
  1. A3 1.8T (2000) non starter
    By chinhead in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2010, 20:34
